Hi bros & sis,
anyway to find out if the ignition coil is faulty? what my fren encountering is when he's doing higher boost (0.85) or full throttle, he'll get to hear some piak piak sound (misfiring) and boost at times will be cut off, will also don't feel the "force" coming in more.
was told most likely be a ignition coil issue... is it true??
Ignition Coil faulty? Misfiring issue...
TS...boost? wat is ur ride? wat does 0.85 boost got to do in relation w full throttle? r u trying to say full boost?
if u r honda ride..unless u tc ur ride..u cant be boosting....and if u TC ur ride...did u get it tune? wat is ur max boost? r u sure its misfiring or pinging?
Turbo...
sTocK iS beST....
世界上ä¸
sTocK iS beST....
世界上ä¸
