Why Cannot Start (Ignition Cable pulled out during Idling)?
cy002288
Post by cy002288 » Sun Dec 19, 2010 5:07 pm
During Idling one of the 4 ignition cable of my '96 Civer SiR was pulled out and the engine stalled. After pluged back the cable the engine could not be started.
The ignition socket seems clean and plugged in and out a few times but engine just cannot be started.
I also tried to start with the accelator pedal pressed to the floor but no use.
Battery is strong.
I have checked the ignition fuse (location 9) and a 40A ignition fuse under the bonnet.
What couold be the reason and how to solve?
e240
Re: Why Cannot Start (Ignition Cable pulled out during Idlin
Post by e240 » Mon Dec 20, 2010 9:09 pm
cy002288 wrote:During Idling one of the 4 ignition cable of my '96 Civer SiR was pulled out and the engine stalled. After pluged back the cable the engine could not be started.
Battery is strong.
You might have damaged the coil or ignitor in the distributor.
Turbo DC2 Type R
Proudly Sponsored by MFactory Competition Products for all Hondas!
TeamMFactory.com
UltraBear
Post by UltraBear » Tue Dec 21, 2010 3:48 am
Battery is strong.
==> ignition coil burnt liao!!! need to replace...
