wheel spacers doubts
speedsterdarren
Post by speedsterdarren » Fri Oct 08, 2010 5:39 pm
just bght a set of 5 lug type wheel spacer form a fellow bro..
was being told that it will not be advisable to track using spacers izzit true...this set of spacers looks quite firm to me thou... :wink:
gurus pls advise.. :wink:
Mugen Boi
Location: Lor Ah Soo, Potong Pasir, Bishan, Leng Kee, Hillview
Post by Mugen Boi » Fri Oct 08, 2010 10:06 pm
think he might b referring 2 other stuffs related 2 using spacer like ur wheel studs...is there enough thread 2 screw ur lug nuts in etc
speedsterdarren
Post by speedsterdarren » Mon Oct 11, 2010 12:57 am
Mugen Boi wrote:think he might b referring 2 other stuffs related 2 using spacer like ur wheel studs...is there enough thread 2 screw ur lug nuts in etc
yes bro...this particular set of lug spacers im using does not compromise the lug's length at all in fact it even looks slightly longer than orig lugs...hope u get what i mean.. :oops:
Silver
Post by Silver » Sun Oct 17, 2010 5:10 pm
Its ok to use spacers if your wheel studs is change to longer length ones, so that the wheel lugs are still able to screw in to a substantial amount... :) :)
