Air Con working intermediately
silver8_0
Post by silver8_0 » Sat Sep 04, 2010 11:21 am
Hi all, my air con suddenly stops working yesterday after i start my car and all it blows out r normal wind.... then after about 5 mins, it suddenly become cold again.... and remain cold for the rest of the day... did stop and restart engine twice but air con still cold.
then at night, after parking my car for abt 10 mins, when i restart the engine, same thing happens again... air con not cold but resume back to normal after 5 mins....
anyone know the reason? Fan spoil? no gas?
Appreciate your advise.
Tks.
funksoulbro
Forum Administrator
Forum Administrator
Re: Air Con working intermediately
Post by funksoulbro » Sat Sep 04, 2010 1:34 pm
silver8_0 wrote:Hi all, my air con suddenly stops working yesterday after i start my car and all it blows out r normal wind.... then after about 5 mins, it suddenly become cold again.... and remain cold for the rest of the day... did stop and restart engine twice but air con still cold.
Tks.
cant be the blower or fan...might be compressor or cooling coil problem liao...
ImageImage Image
silver8_0
Post by silver8_0 » Sat Sep 04, 2010 4:28 pm
Tks.
Thanks bro.... so i need to get it checked or better to wait n see?
Will it cause additional related major damage if i wait n see?
how much is it to replace either the compressor or cooling coil?
Any good workshop to recommend?
funksoulbro
Forum Administrator
Forum Administrator
Post by funksoulbro » Sat Sep 04, 2010 6:03 pm
Tks.
i think u just wait and see...unless u cant tahan it or worried. I dun think it will cause additional related damage. Recon ones are not ex...prices vary actually.
ImageImage Image
mugen_yaz
Post by mugen_yaz » Mon Sep 06, 2010 11:46 pm
Tks.
u can try mark kool @ wdlands industrial park e1...... service wise is good 4 me... change recon comp 2 yrs ago until now still running well.
micloh81
have same problem
Post by micloh81 » Wed Sep 29, 2010 4:05 pm
Hi
have you resolve your problem? whr did you go and how much is the damage? when the outside temp does not show on dashboard, the aircon is not cold...
silver8_0
Re: have same problem
Post by silver8_0 » Fri Dec 24, 2010 3:09 pm
micloh81 wrote:Hi
I jus went to KM yesterday and they recommend to do a swtich relay n monitor first.
The problem happens again this morning and the service advisor recommends replacing the magnetic coil and clutch and cost is about $600.
They say mosting likely is the clutch worn out.
Sian..... Dunno what is true....
silver8_0
Post by silver8_0 » Fri Dec 24, 2010 3:16 pm
mugen_yaz wrote:
silver8_0 wrote:
funksoulbro wrote: cant be the blower or fan...might be compressor or cooling coil problem liao...
Hi, you have the unit number or shop name?
how much you spend to change? KM charging me $600 plus to change the coil n clutch or $1k plus to replace the compressor.
matias80sg
Post by matias80sg » Thu Jan 27, 2011 9:34 pm
Hi bro,
I have similar prob lately. Suggest u will open ur bonnet and observe if your magnetic clutch is engaging when compressor cut in. If compressor cut in but magnetic clutch doesnt engage u will use a spanner to light tab on it and feel if there is magnetic power. If yes, it is likely to be magnetic clutch wore out. I recently encounter similar prob and has been rectified at Tomika aircon specialist located at Ubi. The whole compressor was dismantled and magnetic clutch remove and balanced. The ac pulley bearing also changed. Refill oil and gas. Total cost less than 230$. I ask the mech how long my FD compressor will last. They claim that honda compressor is v durable. However, the magnetic clutch and bearing required constant repair (2-3yrs). Some un-prof workshop will likely to suggest replacement of compressor.
Check out their site: http://www.tmkautoaircon.com/
Hope the above will be useful.
Gresini
Post by Gresini » Sat Feb 19, 2011 12:09 pm
did KM makan your meat sir?
