Idle problem
MR Spyder
Idle problem
Post by MR Spyder » Fri Feb 12, 2010 2:50 pm
Guys, I'm facing a prob with my car's idling. It'd fluctuate between 600-900rpm all of a sudden, and at times, the car "shivers" like it's on e verge of stalling.
Issit due to a dirty throttle body?
Any idea what's wrong? :(
jellyfish
Post by jellyfish » Fri Feb 12, 2010 8:01 pm
have you done any mods recently?, try reset your ecu by removing your battery terminal for few mins then reattatch it, drive ard let the ecu relearn, should be ok, or else it might be due to idle valve or dirty tb due to lousy filtration :wink:
mango
daboy14
Idle prob
Post by daboy14 » Sun Feb 14, 2010 1:24 am
Clean first ur iacv then im..
If all else fails reset ur ecu by removing
the ecu fuse loc at the fuse bix for at least
15.. This wud rebootvthe system and let the
ecu "idle leaen" again
daboy14
Idle
Post by daboy14 » Sun Feb 14, 2010 1:31 am
"idle learn"
