Help!
Am3thyst
Help!
Post by Am3thyst » Sun Jan 31, 2010 11:04 pm
Hi bros,
hope someone here can help me out with trying to find out whats wrong with my eg4 3dr..
this evening after work..started my car..3 things happened..
1. handbrake light doesn't go off even after handbrake is released.
2. aircon no longer cold
3. cabin light no longer working.
i know its like damn random..and i can't figure out if all three problems are related or seperate...
any help will be greatly appreciated..
prostcode
Post by prostcode » Mon Feb 01, 2010 2:07 am
1) top up brake fluid.
2) go mark cool.
3) change bulb.
1992 Honda Civic Si (EG5)
1996 Honda Civic SiR (EK4)
2007 Subaru Impreza WRX (GDA)
Am3thyst
Post by Am3thyst » Mon Feb 01, 2010 6:38 am
prostcode wrote:1) top up brake fluid.
2) go mark cool.
3) change bulb.
brake fluid level is good.
aircon just service less than a month ago..
bulb was also just changed to LED less than a month ago..
archenemy
Post by archenemy » Mon Feb 01, 2010 6:08 pm
check the fuse for your cabin lights...
18luohan
fuse
Post by 18luohan » Mon Feb 01, 2010 6:57 pm
very obvious...FUSE BLOWN
honda77
Post by honda77 » Mon Feb 01, 2010 11:15 pm
Check the LED lighting installed. Might be shorted.
Check the fuses also n also the battery charging.
Am3thyst
Post by Am3thyst » Tue Feb 02, 2010 7:03 am
thank you forr all the replies..
started the car yesterday morning and evening..and all the problems weren't there..
not sure what's going on also..will continue to monitor the next few days...
thanks again for all the help..
18luohan
fuse
Post by 18luohan » Tue Feb 02, 2010 10:09 am
it will come back...confirm!
after i remove the LED bulb, problem solve!
