can oem dc5 k20 type r cam install on fd2m?
marcus soon
Post by marcus soon » Wed Jan 20, 2010 12:11 am
eeee78
SHC Die Hard!!!
SHC Die Hard!!!
Post by eeee78 » Wed Jan 20, 2010 9:05 am
CAN!
TCSS Emperor!
讲鸟è¯
VBlaster_W211
Post by VBlaster_W211 » Wed Jan 20, 2010 9:26 pm
You need to change the entire cylinder head, not just the cams.
K20A cams have additional wild cam lobe that is activated on VTEC. FD2M does not have that provision.
Besides changing the cylinder head, you'll also need KPro. And while you're at it, better build the lower block for high revs and compression. That's where the wild cam VTEC makes its power, from 5000+ to 8400rpm.
eeee78
SHC Die Hard!!!
SHC Die Hard!!!
Post by eeee78 » Thu Jan 21, 2010 10:15 am
Just do an engine swap.. :twisted:
TCSS Emperor!
讲鸟è¯
