Comments on Final drive?
Honda30
Post by Honda30 » Thu Dec 03, 2009 5:35 pm
Can I ask whether it is advisable to run B20 with 4.765 FD? What are the pros and cons? Cos I think usually B20 is with 4.4.FD. Will feel funny if a high torque engine is combined with a high FD? better to use a B18 with high FD? Pls advise...
streetz Project
Re: Comments on Final drive?
Post by streetz Project » Thu Dec 03, 2009 11:09 pm
Honda30 wrote:Can I ask whether it is advisable to run B20 with 4.765 FD? What are the pros and cons? Cos I think usually B20 is with 4.4.FD. Will feel funny if a high torque engine is combined with a high FD? better to use a B18 with high FD? Pls advise...
DEpend on the distance u wanne run boss..
Honda30
Post by Honda30 » Thu Dec 03, 2009 11:28 pm
hmm...can elaborate? Just want to have a powerful car for normal daily driving + occasional speeding if go malaysia. FC should not be too bad. Any recommendation?
streetz Project
Post by streetz Project » Fri Dec 04, 2009 11:14 pm
So far it be finewith a 4.4fd on b20 for normal driving + occasional speeding...too high fd & grearing not advisable for normal driving..
Im nt pro but juz abit here & there knowledge..
Sting3Rhea
Post by Sting3Rhea » Sat Dec 05, 2009 2:30 am
Also depends on your gearing, depends how long is the place you want to play~ Mine 1 to 3 close, 4 and 5 far~ FD 4.785~ Good for cruising~
JDM: Making Your Car Look Like Another Stock Car.
Honda30
Post by Honda30 » Sat Dec 05, 2009 10:51 am
Sting3Rhea wrote:Also depends on your gearing, depends how long is the place you want to play~ Mine 1 to 3 close, 4 and 5 far~ FD 4.785~ Good for cruising~
beside going to workshop, any easier way to know my gear ratio?
Mugen Boi
Location: Lor Ah Soo, Potong Pasir, Bishan, Leng Kee, Hillview
Post by Mugen Boi » Sat Dec 05, 2009 9:20 pm
most probably ur gearbox will b stock EK4 so no worries in going 2 a wksp n getting it checked...unless u bought ur EK4 2nd hand n got a modified gearbox :wink:
Newbie2dr
Post by Newbie2dr » Sat Dec 05, 2009 10:45 pm
Bro firstly depend on what type of engine u using B16, B18 or B20, Secondly, what distance you want to play?there is no gearing to fit all senerios, for instance some play carpark or short distance , they prefer high FD, while play 40 tangs prefer lower FD.
as what street project say using B20 it is reasonable to using 4.4 or 4.2 , depending on what mods have been done on the B20.....Heard of B20 using 4.785 but its mean for hardcore racing, daily use, fuel consumption is high.
As for B18 or B16 Stock, its advisable to use 4.785 , using the high FD to make up for the torque which B20 have.
Cheers
grandpa-VTEC
Post by grandpa-VTEC » Sun Dec 06, 2009 1:05 pm
what abt in sepang??
Speeding has never Killed anyone....suddenly becoming stationary is what Kills you ---- jeremy Clarkson
Newbie2dr
Post by Newbie2dr » Mon Dec 07, 2009 12:42 am
grandpa-VTEC wrote:what abt in sepang??
depends on what engine
superkoh
Post by superkoh » Wed Feb 17, 2010 3:19 am
whats your rpm range when at 100km/h
saint jo
Post by saint jo » Wed Feb 17, 2010 7:27 am
b20...bhp around how much...how abt tq? if its a good builld...high on power...lower FD will suit better...more distance to pull...
b18...using a 4.785 FD is usually nicest combo...will be abit higher at 5th gear..
all this is base on stock b16 gb gear ratio...
Turbo...
sTocK iS beST....
世界上ä¸
noobdriver
Post by noobdriver » Wed Feb 17, 2010 10:39 pm
just to sidetrack a little, will a 4.785 fd from a dc2r fit a stock b16 gearbox. I've heard that you need the LSD to fit the 4.785. Myth or fact? it does not make much sense that you need an LSD to fit a FD.
e240
Post by e240 » Fri Feb 19, 2010 4:40 pm
noobdriver wrote:just to sidetrack a little, will a 4.785 fd from a dc2r fit a stock b16 gearbox. I've heard that you need the LSD to fit the 4.785. Myth or fact? it does not make much sense that you need an LSD to fit a FD.
The DC2R '98 onwards have a bigger ring gear than a B16A. You can't just fit a FD from a DC2R into a B16A.
If you intend to then fit a DC2R FD & LSD into a B16A box, you need to modify a few more things in the B16A gear box, First gear etc comes to mind.
Your best bet is to purchase an aftermarket unit. My recommendation is to also install an LSD at the same time. All front wheel drives should have an lsd. MFactory makes all the gears you need at very competitive prices.
Turbo DC2 Type R
Proudly Sponsored by MFactory Competition Products for all Hondas!
TeamMFactory.com
e240
Post by e240 » Fri Feb 19, 2010 4:41 pm
It wouldn't be a problem at all. Infact, if it were me, I'd be running a 4.9
:-p
Most people retain the 4.4 because thats stock in most boxes.
Turbo DC2 Type R
TeamMFactory.com
