HiD issue!
slow pok
HiD issue!
Post by slow pok » Sun Nov 01, 2009 8:09 pm
hi guys out !! really nid yr help!
i am pretty sick of the stock lights which is yellow white and i wish to change it to blue hid! But i heard the hid conversion is pretty ex (got not much money! :cry: ) so i was planing to buy a blue white bulb and install it myself but does it fit well? and legal?
and also i saw a pair of white blue bulbs in fairprice extra! duno wherther it suits my car and legal?
pls reply me!!! thanks guys! :o
airborne
Post by airborne » Mon Nov 02, 2009 12:56 am
i think you can just drive down to any accessories shop (autobacs, mcwell etc) and ask them to help check the bulb size. perhaps you can ask if the voltage or watts (im not sure here) is compatible. usually they will install it for you at a small price but you can attempt it yourself and diy.
let us know how it goes : ) im a noob diy-er myself too hehe
fsf
Re: HiD issue!
Post by fsf » Mon Nov 02, 2009 1:13 am
white lights are never legal unless factory fitted HID
bengteck
Post by bengteck » Mon Nov 02, 2009 1:44 am
if yours a 1.8 then you need to switch max 4000k HID
but its still a bit yellowish (you'll enjoyed a few secs of white when starting)
since yours a triple headlamp it should be under the same as fd civic
HB3/4, double check with the shop to confirm
do you know hid bulbs cost a bomb each?
slow pok
Post by slow pok » Tue Nov 03, 2009 9:41 am
airborne wrote:i think you can just drive down to any accessories shop (autobacs, mcwell etc) and ask them to help check the bulb size. perhaps you can ask if the voltage or watts (im not sure here) is compatible. usually they will install it for you at a small price but you can attempt it yourself and diy.
so bro u mean i gonna nid the whole Hid conversion to be done? thats very ex man :cry: !!! btw i'm a noob diy-er too :lol:
slow pok
Post by slow pok » Tue Nov 03, 2009 9:45 am
bengteck wrote:if yours a 1.8 then you need to switch max 4000k HID
oh i will have a check with some shops, thanks for yr advice!
those Hid bulbs i saw in ntuc cost less den 30 :twisted: !!! so i was planning if it fits!!! :lol: but i will prefer abit blue blue type, duno wherther its approve anot......... :(
Omantay
Post by Omantay » Fri Nov 06, 2009 9:20 am
if u want u can change to HID ..... will cost about $250+ (no high / low beam) i did it on my Vios last time for about $400+ (with high/low beam)
Best Regards
Cliff Tay aka Omantay
Straight road is for fast car.....Corner is for fast driver
ichibawa
Post by ichibawa » Fri Nov 06, 2009 10:17 am
Don't change to HID lah. Will keep getting cursed by the driver in front of you. Just get the OSRAM night breaker bright enough already.
fannboy
Post by fannboy » Fri Nov 06, 2009 12:15 pm
isnt HID kits in the market now less than $200 including installation?
There's many many many shops doing this, just need to find a reputable one and get a good installation done.
slow pok
Post by slow pok » Fri Nov 06, 2009 11:30 pm
ichibawa wrote:Don't change to HID lah. Will keep getting cursed by the driver in front of you. Just get the OSRAM night breaker bright enough already.
lols, i got think of that la but since alot ppl do that and hurt my eye now is the time i'm going to revenge!!! :lol:
slow pok
Post by slow pok » Fri Nov 06, 2009 11:31 pm
fannboy wrote:isnt HID kits in the market now less than $200 including installation?
wow! thats really cheap!
slow pok
Omantay wrote:if u want u can change to HID ..... will cost about $250+ (no high / low beam) i did it on my Vios last time for about $400+ (with high/low beam)
wow damn ex! but i wanna keep it simple and can diy de juz like changing the bulb..... 8)
