Vibration When Moving Off
Been experiencing this everytime I move off after stopping since 40+k mileage. Workshop told me its problem with start-up clutch but problem still persists after changing the transmission fluid. Hope to get some advise on where I can go to or what can be done to solve this problem. Thanks
Re: Vibration When Moving Off
Maybe is engine mounting can ask your workshop to check. maybe is the gearbox mounting.laiyee26 wrote:Been experiencing this everytime I move off after stopping since 40+k mileage. Workshop told me its problem with start-up clutch but problem still persists after changing the transmission fluid. Hope to get some advise on where I can go to or what can be done to solve this problem. Thanks
JAZZ UP YOUR LIFE WITH JAZZ
Before you add any more "snake oil" into your clutch fluids, maybe it should be the right thing for you to consult a diagnotics expert workshop for real trouble-shooting.laiyee26 wrote:Thanks. Will check it out.
If you ride is still under warranty, just go back to the agent to get it fixed.
If not, I highly recommend u www.riverviewauto.com.sg for expert opinion & solving the root cause of your ride's problems. And just to add, this is a reputable & highly recommendly workshop in many forums and they are ethical business and confirmed "no chop carrot-head" when u go there.
