Vibration When Moving Off
laiyee26
Post by laiyee26 » Wed Sep 30, 2009 1:42 am
Been experiencing this everytime I move off after stopping since 40+k mileage. Workshop told me its problem with start-up clutch but problem still persists after changing the transmission fluid. Hope to get some advise on where I can go to or what can be done to solve this problem. Thanks
intotead
Re: Vibration When Moving Off
Post by intotead » Wed Sep 30, 2009 9:10 am
laiyee26 wrote:Been experiencing this everytime I move off after stopping since 40+k mileage. Workshop told me its problem with start-up clutch but problem still persists after changing the transmission fluid. Hope to get some advise on where I can go to or what can be done to solve this problem. Thanks
Maybe is engine mounting can ask your workshop to check. maybe is the gearbox mounting.
JAZZ UP YOUR LIFE WITH JAZZ
Silver
Post by Silver » Wed Sep 30, 2009 11:35 am
The vibration is due to clutch slippage when moving off.... try look for this guy in Fit/Jazz forum by the name of Buddyclub.... he sells a oil conditioner that helps to eliminate the vibration... :) :)
laiyee26
Post by laiyee26 » Wed Sep 30, 2009 6:20 pm
Thanks. Will check it out. :)
maddog220
Post by maddog220 » Thu Oct 08, 2009 8:06 am
laiyee26 wrote:Thanks. Will check it out. :)
Before you add any more "snake oil" into your clutch fluids, maybe it should be the right thing for you to consult a diagnotics expert workshop for real trouble-shooting.
If you ride is still under warranty, just go back to the agent to get it fixed.
If not, I highly recommend u www.riverviewauto.com.sg for expert opinion & solving the root cause of your ride's problems. And just to add, this is a reputable & highly recommendly workshop in many forums and they are ethical business and confirmed "no chop carrot-head" when u go there.
