brakes jutters when braking at high speeds
kev
Post by kev » Fri Sep 25, 2009 2:57 pm
my brakes jutters when i slow down upon braking at 60km and abv..anyone knows wats wrong?
Silver
Post by Silver » Fri Sep 25, 2009 3:51 pm
4 things I can think of.... brake pads loose.... or calipers loose... or rotors warp... or brake pump leaking... :) :)
eeee78
SHC Die Hard!!!
SHC Die Hard!!!
Post by eeee78 » Fri Sep 25, 2009 5:16 pm
High chances rotor warp or uneven brake pads.
TCSS Emperor!
讲鸟è¯
xhareshx
Post by xhareshx » Fri Sep 25, 2009 6:09 pm
i used to feel the brake jutter when i was braking from above 150km/h. tot its was a brake issue.. my mechanic said its issues with the rims. fair enough after i changed rims all perfectly fine..
Num3ga
Post by Num3ga » Fri Sep 25, 2009 10:35 pm
Usually rotor warp :( Aiyah spend money again leh
grandpa-VTEC
Post by grandpa-VTEC » Sat Sep 26, 2009 12:21 am
Num3ga wrote:Usually rotor warp :( Aiyah spend money again leh
warp can skim one ma...but try nt 2 skim more than twice for one rotor...if after skimming still vibrate could be yr rims and tyres...
Speeding has never Killed anyone....suddenly becoming stationary is what Kills you ---- jeremy Clarkson
