This is what happen when I remove my rim. Anyone can advise if this is a serious case?
Agreed...Mine got the similiar problems & i just change the pair of rubber boot only till now....LTM wrote:just change the rubber boot and the grease can already..unless you have the tack tack tack noise when you turn full lock to one side...in that case you have to change the driveshaft as well....
