Stinky petrol smell in my car! Pls Advice!
STILLLWATERS
Post by STILLLWATERS » Tue Jun 16, 2009 5:26 pm
i can smell the petrol or exhaust fumes in my car. Gonna die from breathing it everyday. It's worst when i high rev and drag the car. Anyone got any clue? Undercarriage concealing not good anymore, or the aircon or it's the exhaust pipe? Comments are very welcome!
fulsik
Post by fulsik » Tue Jun 16, 2009 10:38 pm
i have the same prob with my car too. let's hear it from the experts.
Mach
fuel pump
Post by Mach » Tue Jun 16, 2009 11:17 pm
fulsik wrote:i have the same prob with my car too. let's hear it from the experts.
If it's petrol smell it may be the fuel pump leaking that requires urgent attention (fuel pump leak and oil patch can be seen from undercarriage near fuel tank) as it is flammable especially when parked near dry grass/burning incense, etc.
If it's vehicle exhaust smell, check that aircon vent are closed and seek an experienced audio/aircon shop to check that the vents are tight.
Urgent attention needed
STILLLWATERS
Post by STILLLWATERS » Wed Jun 17, 2009 7:48 pm
hey Mach! Anywhere or anyone to recommend? My undercarriage very holey also. The smell is worst when i high rev. Could it be my injector injecting too much petrol and the engine cannot burn? Cuz i have a blowoff valve and my car is not tuned. So my engine running rich on petrol. I ready don know. More advice!
sphinx_lover
SHC Die Hard!!!
SHC Die Hard!!!
Post by sphinx_lover » Wed Jun 17, 2009 8:50 pm
Start your engine and open the bonnet..The smell may likely comes from the leaking pipes at your fuel regulator area or injectors :roll:
Mach
Re: Stinky petrol smell in my car! Pls Advice!
Post by Mach » Wed Jun 17, 2009 11:15 pm
STILLLWATERS wrote:hey Mach! Anywhere or anyone to recommend? My undercarriage very holey also. The smell is worst when i high rev. Could it be my injector injecting too much petrol and the engine cannot burn? Cuz i have a blowoff valve and my car is not tuned. So my engine running rich on petrol. I ready don know. More advice!
sorry, i'm not familar with tuned cars maybe you shld go back to your regular mechanic which altered your set up.
watt
FUMES
Post by watt » Thu Jun 18, 2009 11:46 am
i used to have the same prob last time in my eg8, in the end found the injector o-ring worn off. after replaced o ring, no more smell.
AhAx
Post by AhAx » Wed Oct 14, 2009 4:49 pm
Roughly how much to replace the ring..?
grandpa-VTEC
Post by grandpa-VTEC » Fri Oct 16, 2009 10:10 pm
check yr fuel lines and injector O'rings for any leaks...fuel pump and also the fuel filter area...if in doubt...replace...esp when u know that its an old car e.g EF,EG series which are more than 10 years old...most of the time they've never been replaced before...so my best bet is to just simply bite the bullet and one shot replace all the rubber fuel hoses...
Speeding has never Killed anyone....suddenly becoming stationary is what Kills you ---- jeremy Clarkson
