Causes of high fuel consumption. Updated 26Jan2007
Civic model year 1980 - 2000
kookk
Re: What can cause high fuel consumption? Some Tips
Postby kookk » Fri Jan 26, 2007 1:42 am
AhHwo wrote:Where and how to check if got thermostat?
http://www.shc-forum.com/viewtopic.php?t=90495
by the way... Gari, how to check for codes for faulty part? use computer? my bro's vehicle siao siao liao... when moving off, stuck at rpm2, something is wrong...zzzz O2 sensor, or what sensor goes wrong?
vehicle no power, drinking fuel...[/quote]
Got CEL? No CEL, got no code. Got CEL than got code. Only needle stuck or car cannot even accelerate pass rpm2k?
garilee
Postby garilee » Fri Jan 26, 2007 11:39 am
kookk wrote:by the way... Gari, how to check for codes for faulty part? use computer? my bro's vehicle siao siao liao... when moving off, stuck at rpm2, something is wrong...zzzz O2 sensor, or what sensor goes wrong?
wat car?? wat are the symptons when moving..??
AhHwo
Postby AhHwo » Fri Jan 26, 2007 5:46 pm
civic Esi. Can accelerate pass rpm2k, after 2k increase damm slow, like something kanna stuck... i full throttle also same.. loss of power...
after that i reset the ecu... den ok... but i tink this will come back again...
den when on the air-con.. the whole vehicle like tortise.. move damm slow..
alot of misfire...
something like this article.http://www.myhonestmechanic.com/article ... rich.shtml
garilee
Postby garilee » Sat Jan 27, 2007 12:13 am
AhHwo wrote:civic Esi. Can accelerate pass rpm2k, after 2k increase damm slow, like something kanna stuck... i full throttle also same.. loss of power...
alot of misfire...
the article already answer for u.. its definitely the o2 sensor dead or dying
AhHwo
Postby AhHwo » Sat Jan 27, 2007 12:18 am
alot of misfire...
i try replacing the o2sensor. if not means leaking or dirty intake valve. i go check tommorow. let u know the result.. hahazz :x :x
weirong
Postby weirong » Wed Feb 07, 2007 12:42 am
hello.
does resetting ecu help to cure my chui fc.
its getting from bad to wrose leh
8.8 now
SIAN.
the previous owner last time changed cams and injectors
i think the changed injectors still around but the cams now stock.
must get vafc to help?
Thug
Postby Thug » Wed Feb 07, 2007 10:45 am
weirong wrote:.....
Hi, how can VAFC to help FC wif stock cams etc?
-:- I grow up very poor. If I wasn't a boy; I would have nothing to play with -:-
kookk
Postby kookk » Wed Feb 07, 2007 5:38 pm
weirong wrote:hello.
8.8 now
SIAN.
Change your injector to stock lor. Stock esi injectors should be cheap.
AhHwo
Postby AhHwo » Wed Feb 07, 2007 10:15 pm
8.8 now
SIAN.
what petrol u pump? shell or esso?
jytan
Postby jytan » Wed Feb 07, 2007 11:42 pm
8.8 now
SIAN.
My FC also 8.5 nia ... have VAFC .. but still the same ... wanna tackle the issue together?
jytan
weirong
Postby weirong » Thu Feb 08, 2007 9:54 pm
8.8 now
SIAN.
he told me to he changed injectors and never took out when he sold his car. but then donno whether agent got take out anot. how to check ah!
pls advise!
forrestcat
Postby forrestcat » Fri Feb 09, 2007 3:46 pm
8.8 now
SIAN.
pls advise!
Bro, go get a VAFC leh.... :D
Let Bro Vic tune for you see any improvement
weirong
Postby weirong » Fri Feb 09, 2007 8:21 pm
ooohh. when i got neough budget i buy vafc lor. now stress. road tax, insurance, everything come this month
chui.
vic still got tune civics ah! i thought that time he say no more do liao
garilee
Postby garilee » Sat Feb 10, 2007 10:08 am
weirong wrote:he told me to he changed injectors and never took out when he sold his car. but then donno whether agent got take out anot. how to check ah!
pls advise!
this sat got follw us go PG? if have, i help u take alook. anyway, i have 2 sets of stock injectors at hm
weirong
Postby weirong » Sun Feb 11, 2007 4:45 am
pls advise!
i never follow leh. i at chalet. :twisted:
Return to “Civic EF / EG / EK”
Users browsing this forum: No registered users and 3 guests
