Page 3 of 3
Posted: Wed Oct 25, 2006 3:03 pm
by fatelmo
cl7teckie wrote:...BTW, r u sure you can get models like T5500 as cheap as $80 per pair? I was told that it should cost $150 or something. I got lobang for Motorola one(good) with full 2 years local warranty at abt $120 per pair for sure. Cheaper one will be other brands or chieong Motorola one!! Confirmed. and I can use get single unit, so no need to buddy buddy..
Yes Paul,
I am very sure. I have done a a few GBs before for the EDians. As mention is meant for export use. Hence no warranty is given.
Posted: Wed Oct 25, 2006 3:08 pm
by cl7teckie
fatelmo wrote:cl7teckie wrote:...BTW, r u sure you can get models like T5500 as cheap as $80 per pair? I was told that it should cost $150 or something. I got lobang for Motorola one(good) with full 2 years local warranty at abt $120 per pair for sure. Cheaper one will be other brands or chieong Motorola one!! Confirmed. and I can use get single unit, so no need to buddy buddy..
Yes Paul,
OIC...catch up the details with you...As long as it is orginal Motorola, that's fine...if it is Chieong one(which like EXACTLY the same!!) , then the buyer must know that's all. I was quoted a chieong pair was about $77 per pair...it is not abt warranty.
Like I said, models used by Accordian or SHC here MUST be export model...Legal one here are totally diff. freq, so cannot be used.
Posted: Tue Nov 07, 2006 10:40 am
by irvan
Hi, may i know if T5000 model is compatible to T5500 which most of you guys are using?
Posted: Tue Nov 07, 2006 11:44 am
by sleepwalker
irvan wrote:Hi, may i know if T5000 model is compatible to T5500 which most of you guys are using?
should be okay as long u have a main channel & sub channels
if not wrong mine is also the same as yours
