Pictures of meeting points for SHC Convoy
SHC's visit to the Honda plant in Alor Gajah, Malaysia
fatelmo
East Deviants Moderator
Postby fatelmo » Wed Oct 25, 2006 3:03 pm
cl7teckie wrote:...BTW, r u sure you can get models like T5500 as cheap as $80 per pair? I was told that it should cost $150 or something. I got lobang for Motorola one(good) with full 2 years local warranty at abt $120 per pair for sure. Cheaper one will be other brands or chieong Motorola one!! Confirmed. and I can use get single unit, so no need to buddy buddy..
Yes Paul,
I am very sure. I have done a a few GBs before for the EDians. As mention is meant for export use. Hence no warranty is given.
cl7teckie
Postby cl7teckie » Wed Oct 25, 2006 3:08 pm
Yes Paul,
OIC...catch up the details with you...As long as it is orginal Motorola, that's fine...if it is Chieong one(which like EXACTLY the same!!) , then the buyer must know that's all. I was quoted a chieong pair was about $77 per pair...it is not abt warranty.
Like I said, models used by Accordian or SHC here MUST be export model...Legal one here are totally diff. freq, so cannot be used.
irvan
Postby irvan » Tue Nov 07, 2006 10:40 am
Hi, may i know if T5000 model is compatible to T5500 which most of you guys are using?
sleepwalker
Postby sleepwalker » Tue Nov 07, 2006 11:44 am
irvan wrote:Hi, may i know if T5000 model is compatible to T5500 which most of you guys are using?
should be okay as long u have a main channel & sub channels
if not wrong mine is also the same as yours
Return to “Honda Plant Visit”
