Honda : Engine Codes
Re: Honda : Engine Codes
Ok I am no expert on all Hondas but this is as accurate as I can provide you guys on the exact information from the factory. (I was an apprentice there for two years)
All are for JDM specs unless stated. Cars with JHM in front of the actual code specifies export (UK) cars. Any thing else like E-EG is JDM spec
E-DB8 - '93 - Integra Si VTEC, SiR, SiR-G 4dr = 1.8l DOHC VTEC = B18C
E-DB8 - '95 - '98 Integra Type R 4dr(95 spec) = 1.8l DOHC VTEC = B18C (R)
E-DB8 - '98 - '00 Integra Type R 4dr(98 spec) = 1.8l DOHC VTEC = B18C (R)
E-DC2 - '94 - '96 Integra Si VTEC 2dr = 1.8l DOHC VTEC =B18C
E-DC2 - '95 - '96 Integra SiR,SiR-G 2dr = 1.8l DOHC VTEC =B18C
E-DC2 - '95 - '98 Integra Type R 2dr(95 spec) = 1.8l DOHC VTEC = B18C (R)
E-DC2 - '98 - '00 Integra Type R 2dr(98 spec) = 1.8l DOHC VTEC = B18C (R)
LA-DC5 - '01 - '03 Integra iS 2dr = 2.0l DOHC i-VTEC = K20A2
LA-DC5 - '01 - '03 Integra Type R 2dr = 2.0l DOHC i-VTEC = K20A (R)
ABA-DC5 - '03 - xx Integra iS 2dr = 2.0l DOHC i-VTEC = K20A2
ABA-DC5 - '03 - xx Integra Type R 2dr = 2.0l DOHC i-VTEC = K20A (R)
EC8 - '87 - '91 Civic GL 3dr = 1.3l SOHC = D13B
ED3 = '87 - '91 Civic GL 4dr - 1.5l SOHC = D15B3
E-EF3 - '87 - '91 Civic Si 3dr = 1.6l DOHC = D16C (ZC)
E-EF7 - '87 - '91 CRX Si 3dr = 1.6l DOHC = D16C (ZC)
E-EF8 - '89 - '91 CRX SiR 3dr = 1.6l DOHC VTEC= B16A (1st gen)
E-EF9 - '89 - '91 Civic SiR,SiR II 3dr = 1.6l DOHC VTEC= B16A (1st gen)
JHMEG1 - '92 - '95 CRX ESi 2dr = 1.6l SOHC VTEC = D16B
JHMEG2 - '92 - '97 CRX DEL SOL VTi 2dr = 1.6l DOHC VTEC = B16A2
E-EG2 - '92 - '97 CRX DEL SOL SiR 2dr = 1.6l DOHC VTEC = B16A
JHMEG4 - '92 - '95 Civic LSi 3dr = 1.5l SOHC = D15B
E-EG4 - '92 - '95 Civic MX 3dr = 1.5l SOHC VTEC-E = D15B
JHMEG5 - '92 - '95 Civic ESi 3dr = 1.6l SOHC VTEC = D16B
E-EG5 - '92 -'95 Civic VTi 3dr =1.5l SOHC VTEC = D15B
JHMEG6 - '92 - '95 Civic VTi 3dr = 1.6l DOHC VTEC = B16A2
E-EG6 - '92 - '95 Civic SiR,SiR-G, SiR II 3dr = 1.6l DOHC VTEC = B16A
JHMEG8/JHMEH9 - '92 - '95 Civic ESi 4dr = 1.6l SOHC VTEC = D16B
E-EG8 - '92 -'95 Civic Ferio VTi 4dr =1.5l SOHC VTEC = D15B
JHMEG9 - '92 - '95 Civic VTi 4dr = 1.6l DOHC VTEC = B16A2
E-EG9 - '92 - '95 Civic Ferio SiR 4dr = 1.6l DOHC VTEC = B16A
JHMEK3 (E-EK3/GF-EK3) - '95 - '00 Civic EXi 4dr = 1.5l SOHC = D15B
JHMEK3 (E-EK3/GF-EK3) - '95 - '00 Civic VTi 3dr = 1.5l SOHC VTEC = D15Z
JHMEK3 (E-EK3/GF-EK3) - '95 - '00 Civic VTi 4dr = 1.5l SOHC VTEC = D15Z
JHMEK4 - '95 - '00 Civic SiR 3dr = 1.6l DOHC VTEC = B16A4
JHMEK4 - '95 - '00 Civic SiR 4dr = 1.6l DOHC VTEC = B16A4
E-EK4 - '95 - '98 Civic SiR,SiR II 3dr = 1.6l DOHC VTEC = B16A
E-EK4 - '95 - '98 Civic Ferio Si 4dr = 1.6l DOHC VTEC = B16A
GF-EK4 - '99 - '00 Civic SiR, SiR II 3dr = 1.6l DOHC VTEC = B16A
GF-EK4 - '99 - '00 Civic Ferio Si 4dr = 1.6l DOHC VTEC = B16A
E-EK9 - '97 - '98 Civic Type R 3dr(97 spec) = 1.6l DOHC VTEC = B16B
GF-EK9 - '98 - '00 Civic Type R 3dr(99 spec) = 1.6l DOHC VTEC = B16B
LA-EP3 - '02 - '03 Civic Type R 3dr (JDM) = 2.0l DOHC i-VTEC = K20A (R)
ABA-EP3 - '04 - xx Civic Type R 3dr (JDM) = 2.0l DOHC i-VTEC = K20A (R)
bro, how come my ESi engine code D16Z6?TachiTJRS wrote:Ok I am no expert on all Hondas but this is as accurate as I can provide you guys on the exact information from the factory. (I was an apprentice there for two years)
E-EF3 - '87 - '91 Civic Si 3dr = 1.6l DOHC = Z16C (ZC)
E-EF7 - '87 - '91 CRX Si 3dr = 1.6l DOHC = Z16C (ZC)
Hey Bro, SOHC=Single OverHead Cam DOHC= Double OverHead CamGT4Sky wrote:Hey I'm new and still leaning, just waht to for '92 - '95 Civic Esi 4dr = 1.6l is EG8 or EH9. how to see is it EG8 or EH9.
and what is the diff for SOHC and DOHC??
and what is D16B?
hope someone will help and teach me more about car..
(EG8/EH9 - '92 - '95 Civic Esi 4dr = 1.6l SOHC VTEC = D16B)
Cheers!!
Engine No B16A5?
Can' find the engine number B16A5 in your list?
- DRAGster_CIVIC
Re: Engine No B16A5?
It does not officially exist.mrehman wrote:Can' find the engine number B16A5 in your list?
- terence_hideyoshi
Re: Code
Me to. I also wanna know when will the vtec open as I do understand that at diff speed and rpm that you are travelling on, you can actually delay or early open your vtec. Can advise?carlsberg wrote:hi there,
Can anyone enlighten me on the code for a 2004 VTI?
Thanks lotsa!
To respect others first and others will respect you...
Old School Concerto 1.6 EX-i
Guys there's one more engine u guys left out. Its the 1.6l 16 valves 131ps Sohc D16a7 for the concertos here in singapore. There are 2 variants, the 98ps carburrettor, and the fuel injected one as i mentioned above. In fact, its the same engine block as the esi's D16z, sans the vtec. Cheers guys.
- Team Kunimitsu
- 10 000rpm Over Rev
Re: Old School Concerto 1.6 EX-i
which is better es5, esi & ek3?Jeremy wrote:Guys there's one more engine u guys left out. Its the 1.6l 16 valves 131ps Sohc D16a7 for the concertos here in singapore. There are 2 variants, the 98ps carburrettor, and the fuel injected one as i mentioned above. In fact, its the same engine block as the esi's D16z, sans the vtec. Cheers guys.
- XiaoNick
- 9000rpm Rev Cut
You are using too wide a term which is better.Team Kunimitsu wrote:which is better es5, esi & ek3?
In terms of engine, I will say the ESi engine seem to be more powerful than the ek3 and the ES5.
Power-to-weight ratio ESi will win Ek3 which in turns win ES5
The ES5 is detune to produce more torque rather than hp. I think ESi and Ek3 both produce around 130hp
Both are all the same d16 engines, each one improving it design for different purpose. There also also D5 engines for the Esi But both are quiet similarly matched. 100C +/- will not make much of a significant difference
