Civic model year 1980 - 2000
garilee
- 9000rpm Rev Cut
Post
by garilee » Thu Dec 18, 2008 8:51 am
steadymatrock wrote:Can you support the fact on rigid chassis were deem "not safe"? It supposed to be suspension or ARB to be not too rigid?
Its my personal opinion since most of our cars are daily driven, and "safe" referring to corresponding probs that may crop up. when u stiffen 1 part of the car body, u may cause problems in other area of the car. Hard= brittle.
In yr example, stiff suspension wears off yr bushing faster. arb can change the steering characteristics & big ones place more stress on the chassis components
Version RR => Recon TypeR
garilee
- 9000rpm Rev Cut
Post
by garilee » Thu Dec 18, 2008 8:54 am
bimbo0 wrote:ek4 . b16a engine . using 4-2-1 and 2.5 inch straight through all th way . i find tht th whole car is very soft . issit th 2.5 inch too big ? sorry if you dont understand what i meant . i duno how to phrase it better .
If ur engine is stock, 2.5" is abit too big.. yr exhaust gases shd be losing alot of velocity at low-mid rpms.
bimbo0
Post
by bimbo0 » Fri Dec 19, 2008 12:30 am
garilee wrote:bimbo0 wrote:ek4 . b16a engine . using 4-2-1 and 2.5 inch straight through all th way . i find tht th whole car is very soft . issit th 2.5 inch too big ? sorry if you dont understand what i meant . i duno how to phrase it better .
yea . engine is stock . if im gg to mod my engine a lil , can i keep this exos or change to smaller ?
fancyTHIS
bimbo0
Post
by bimbo0 » Fri Dec 19, 2008 12:32 am
Emperorcivic wrote:bimbo0 wrote:ek4 . b16a engine . using 4-2-1 and 2.5 inch straight through all th way . i find tht th whole car is very soft . issit th 2.5 inch too big ? sorry if you dont understand what i meant . i duno how to phrase it better .
boss, 2.5inch is quite big for a stock b16.
plus u haven tune yet.
thats the reason why u feel its too sluggish. =D
boss's boss . so . power fc or vafc2 ?
fancyTHIS
Emperorcivic
- 9000rpm Rev Cut
Post
by Emperorcivic » Fri Dec 19, 2008 9:06 am
bimbo0 wrote:Emperorcivic wrote:bimbo0 wrote:ek4 . b16a engine . using 4-2-1 and 2.5 inch straight through all th way . i find tht th whole car is very soft . issit th 2.5 inch too big ? sorry if you dont understand what i meant . i duno how to phrase it better .
i would go for a power FC
but if low on budget, a emanage ultimate is good enuff. =)
garilee
- 9000rpm Rev Cut
Post
by garilee » Mon Dec 22, 2008 5:10 pm
bimbo0 wrote:yea . engine is stock . if im gg to mod my engine a lil , can i keep this exos or change to smaller ?
2.5 is overkill. a full dc2r 2.25" will be perfect and u wont need to worry with annual inspection
bimbo0
Post
by bimbo0 » Mon Dec 22, 2008 9:53 pm
garilee wrote:bimbo0 wrote:yea . engine is stock . if im gg to mod my engine a lil , can i keep this exos or change to smaller ?
dc2r's length able to fit my car ? mine is a 4dr . sorry for asking this kind of qns . duno very much abt cars ! ;X
fancyTHIS
Emperorcivic
- 9000rpm Rev Cut
Post
by Emperorcivic » Tue Dec 23, 2008 3:32 am
bimbo0 wrote:garilee wrote:bimbo0 wrote:yea . engine is stock . if im gg to mod my engine a lil , can i keep this exos or change to smaller ?
if im not wrong. YES. =)
cyrix1976
- 10 000rpm Over Rev
Post
by cyrix1976 » Tue Dec 23, 2008 10:06 am
can la, where got cannot one. $$$ do wonder.
Honda EG 4 Dr 2003-2004
Honda EG 4 Dr 2006-2009
Honda DC5 GSR 2009-201_
pioneerpc
- Civic EF/EG/EK Moderator
Post
by pioneerpc » Wed Jan 07, 2009 1:33 am
u have the most amt of money leh!
ESI 2010-2012
Fit 2012-2013
DC5 2013-2014
Colt R 2014-2014
EK4 2014-2016
Wrx 2016-2017
Jazz 2017-2017
GTI 2017 -
tecque
- 1000rpm
Post
by tecque » Wed Jan 07, 2009 3:56 pm
Hello garilee... i have some question between B16B and B18CR.. Can pls help me..
I plan to stroke up my B16B to B18CR by changing the Crankshaft and conrod..
So do u know whether the Injector, Fuel pump, Oil pump or others engine part tat i need to change to B18CR's?? Ar there the same or different?
Thanks if u could help....
Tomeiiiiii
Post
by Tomeiiiiii » Wed Jan 07, 2009 8:37 pm
MoTec is good.
MicroTech also good.
pioneerpc
Post
by pioneerpc » Thu Jan 08, 2009 4:20 am
MoTec is good.
hehehe
ESI 2010-2012
Fit 2012-2013
DC5 2013-2014
Colt R 2014-2014
EK4 2014-2016
Wrx 2016-2017
Jazz 2017-2017
GTI 2017 -
garilee
- 9000rpm Rev Cut
Post
by garilee » Thu Jan 08, 2009 1:49 pm
tecque wrote:Hello garilee... i have some question between B16B and B18CR.. Can pls help me..
1) B18c crank
2) b18c con rods
3) b18c con rod bearings
4) b18c throttle body (b16b=60mm, b18c=62mm)
(the rest of b16b type r parts like timing belt, pumps etc. are all the same/compatible as b18c5)
tanpm
Post
by tanpm » Fri Jan 16, 2009 9:48 pm
hey bro, i just bought a 2nd hand Civic ESI '92, everything is fully stock and im new to this forum.
Any recommendations on how to increase power?
IHE wise, Open Pod + HS + CAI or just the stock air intake (recommendations on filters too, for open and drop in filter)? ,
Header 4-2-1 (is it legal for civics?),
Exhaust (is the stock mid pipe and exhaust good enuff?), lastly what kinda ecu is advisable, say in the range of under 1k including tuning and what are the overall gains if possible.
Thanks in advance (:
