EG/EK Mods & Upgrades-Updated 25Nov08 Revising-NO TCSS!
Civic model year 1980 - 2000
garilee
Post by garilee » Tue Aug 18, 2009 12:14 pm
herong wrote:question to ask, can i turbocharge engine which is high compression? currently running a d16 on high compression, thanks
answer is NO. u want to turbo, u have to lower the comp. can add head gasket or go for low comp pistons. oem d16 comp at 9+ is very good base for mild bolt on turbo
vipergod2000
Post by vipergod2000 » Fri Aug 21, 2009 4:13 am
Hey bro, you mentioned the
"for eg9. the best legal exhaust mod is a b18c5 type r full exhaust system (ie.4-2-1/4-1 header, high-flow cat, mid pipe & muffler). if u get the dc2 muffler, it will be abit shorter so the muffler tip will be slightly under yr rear bumper. if get db8r (4 dr version of dc2), it will be perfect"
Where to get? Is it hard to find? Are a lot of EGs using this? What are the gains / pros / cons / sound ?
Earlier on in the thread its mentioned Remus and Supersprint are the two legal exhausts for the SOHC, but for the DOHC, what are the legal options?
garilee
Post by garilee » Fri Aug 21, 2009 12:17 pm
vipergod2000 wrote:Where to get? Is it hard to find? Are a lot of EGs using this? What are the gains / pros / cons / sound ?
DB8R exhaust are mostly fr halfcuts imported fr japan. Now shd be super rare but i have seen many EKs and EGs using it. best bet is to be patient & watch out in the WTS forum. Mid-high rpm gains and sounds quite loud at high rpm
vipergod2000 wrote:Earlier on in the thread its mentioned Remus and Supersprint are the two legal exhausts for the SOHC, but for the DOHC, what are the legal options?
DOHC & SOHC same. Only can use remuz or super sprint with cert. my guess is the type r muffler shd perform better than those mufflers
boii
Post by boii » Wed Sep 02, 2009 10:17 pm
hi..new here. jus brought a esi month ago ..
tinking of go into turbo.
any good workshop tat dun really charge $$ high in sg??
other than puting in tc , anything else i need to do to the car??
any wat the penatly for tis mod??
thankxx..
silversurfer999
Post by silversurfer999 » Sat Sep 05, 2009 8:27 pm
hi, just installed a hondata s300 in my esi, anyone knows how to engage the launch control function? thanks
garilee
Post by garilee » Mon Sep 07, 2009 2:12 pm
boii wrote:hi..new here. jus brought a esi month ago ..
thankxx..
wats yr budget? Muz remember. cheap=>no gd. Good=>not cheap.
garilee
Post by garilee » Mon Sep 07, 2009 2:14 pm
silversurfer999 wrote:hi, just installed a hondata s300 in my esi, anyone knows how to engage the launch control function? thanks
think u need to install a switch near the clutch pedal for the ecu to sense whether u clutch in/out. Ask joel fr Driven.
boii
Post by boii » Mon Sep 07, 2009 5:55 pm
thankxx..
budget is around 1 - 2k.
which workshop do u intro tat is reliable?
how much horsepower can increase by going into turbo within my budget ?
thankx..
garilee
Post by garilee » Thu Sep 10, 2009 3:17 pm
boii wrote:budget is around 1 - 2k.
thankx..
for your budget, i suggest u spend the $ on strengthening the car handling & replacing wear & tear. Its almost impossible to get a reliable bolt-on turbo set-up with that kind of budget unless u get super lucky from 2nd hand set-ups fr WTS forum.
boii
Post by boii » Thu Sep 10, 2009 8:00 pm
thankx..
thank for ur suggestion ..
i already replace wear n tear, overhual my engine etc..
garilee
Post by garilee » Fri Sep 11, 2009 10:02 am
boii wrote:thank for ur suggestion ..
if u already overhaul yr engine then no point wasting $ to turbo coz u need to strip the engine again to lower the compression. for yr budget, try to get a carbon fibre bonnet, boot, lighter rims, a gd set of final dr with close ratio gears.
close ratio is the best value for $. With a stock esi engine & a set of final dr & close ratio gears, u can easily hold off a stock rex for a few lampposts if launching from start position :finga:
boii
Post by boii » Fri Sep 11, 2009 4:30 pm
ic..thank..
will try to get a close ratio gear..
tinking of going into turbo cos lot of my frend say esi hard to get more power as is single cam ..
civic`esi
Post by civic`esi » Sat Sep 19, 2009 6:33 pm
SINGAPORE is a FINE country .. :evil:
antonnius
Post by antonnius » Sat Sep 19, 2009 8:11 pm
civic`esi wrote:SINGAPORE is a FINE country .. :evil:
totally agree :evil:
cyrix1976
10 000rpm Over Rev
10 000rpm Over Rev
Post by cyrix1976 » Sat Sep 19, 2009 10:08 pm
launch control must be activate thrus the program, your tuner will either set at certain rpm for you or de activate.
mine is set at 4000rpm when i'm using s300 and normal performance tire or 5000 when on semi slick.
need a usb cable and laptop if you wanna do it yourself.
Honda EG 4 Dr 2003-2004
Honda EG 4 Dr 2006-2009
Honda DC5 GSR 2009-201_
