CL Poison Guide (280605)
zhihong
Post by zhihong » Sat Jul 19, 2008 10:00 pm
INTAKE + CAMS + ECU
- DIY CAI - remove resonator & use Alu piping to stock airbox.: $50-$80/- : Anywhere
- K&N Panel Filter element : $80 -$90 : Many Shops
- Spoon Panel Filter Element : $120 : Mikotai
- Mugen Carbon Intake Kit : $1.5kplus : SI, GMS, MR
- Gruppe M Intake Kit : $1.2k: SI, : MR
- HKS Intake Kit : $310 : GR
- K&N Cone in stock air box : $150 :MW, AD
- Apexi SRI : $370+ : AD
- BMC CDA: $550++ : Espace
- Spoon venturi throttle body: swap + $550 : mikotai
- Toda Cam spec A include installation : $3100 : ST ,MR
- HKS F-CON SZ with cable harness & tuning: $2650 : GR
- HKS F con V Pro: $5.4k : GR
- Hondata & Tune $2k+ : Max
- HKS Oil Cooler Kit : $800+ : GR
- Universal 11/14/19 row Oil Cooler kit - $350 SI(DX)
- Spoon ECU - $1.7k SG
- Spoon Final Drive 5.1 - $520 SG
- Mugen CF air intake kit - $1.4k SG
2) EXHAUST + HEADER
- Js Racing Titanium (LTA approved) : $1980 : GR
- [HKS Silent Hi-power (LTA approved): $1600 : GR , $1.4k+ :YB
- Fujitsubo Legalise R (LTA approved): $1.5kplus : ST , $1.3k+ : YB
- Mugen Catback (LTA approved): $ 2600 MR, SI/ MR
- Amuse Titanium : $ 3000+ :SI
- Spoon 4-2 extractor $1200, mikotai
- Toda 4-2-1 CL7 header - $1930
- Six Sigma Racing (USA) custom CL7 header: $2k+ : SI - contact d_iceman for details.
- Mugen 4-2-1 Header + hi-flow Cat: 3k+ SI/ MR
- Spoon Engine Head & Gasket: $700+ :mikotai
- Spoon Carbon Kevlar Spark Plug Cover : $180+ : Mikotai
3) SUSPENSION KITS & BRAKES
- HKS Hypermax III : $3000 : GR
- TEIN Flex : $2000 : GR, ST, Choon
- TEIN Mono Flex: $2400 : GR
- TEIN Super Street : $1400 : GR, ST
- TEIN EFDC : $ : 600+
- Tein S.Tech spring : $400 : LS
- BC coilover: $1200: RT
- Tomei (yap) coilovers : $980 : YB
- Tomei N1 Coilover : $1450 : YB
- Mugen : $2.5k to 2.6k , SI
- Mugen 5adj suspension - $2.6k : MR
- Aragosta coilovers : $3.6k -4K : SI
- Spoon Coilovers : $4K : SI/Mikotai
- Toda Fightex Coilovers: $3K+ : MR
- Koni adjustable yellow dampers + eibach prokit : $1.2k
- Koni Adj. Yellow Damper (CL7/CM5) : $600
- KW coilvers variant 1 : $2k
- Bilstein b12 kit : $1.5k : TSPL
- Springs Espliers : $370
- Springs Eibach : $600 :Espace
- Springs Team Kunimitsu : $650 :LA
- Spoon Calipers : $1900 ST :
- Exzess 4 pot+330mm 2pc rotor+550deg pads+hoses : $2888 MW (promo over)
- Brembo 4pot GT Kit : $4150 MW
- Project Mu 4 Pot : $3500 SI
- Steel Braided Brake Hose : $280 YB : APP $350 a set : Exzess $288 MW
- Brake Pads : Project Mu $120-180; Endless: $250, Feels $350, Mugen $350 +
- Endless 6 Pot Calipers with rotor: $4800
- Dephi brake pads 50-850c : front and back with labour $750
- Wilwood 4pot FSL front + SS Hose, 2pc rotors & EBC Front/Rear Pads :$2.8k : PJ
- Espec 4 pot : $1850 : LT
- JBT 4 pot + 2 pc rotors: $2.8k : YB
- Spoon coilovers - $2.4k - SG
- Spoon brake kit + 300mm 2pc rotor+300deg pads : $2.5K - SG
- Cusco coilovers - $2.2k - $2.4k: MW
- Buddy Club Coilover : $1480
- Alcon Extreme 4pot + 343mm 2pc rotor+550deg pads+SSBH : $4.6 MR
- Pro tune 6 pot + 330mm rotor+pads : $3300 GR
- Air Boomer Suspension : $8k with installation
4) ELECTRONICS & GADGETS
- Apexi RSM + Stand : $350-400+ : ST, GT, YB - Apexi Versa Cruise : $310 : ST
- Apexi NA timer : $180plus :
- Apexi AFC NEO : $700+ Tune $180 : ST
- Pivot Voltage Stabiliser : $160 : MW : $85 : PL
- Pivot SuperEarth G-Cables (Silver type) : $120plus : NG
- Pivot Ign Spark : $128 MW
- Pivot Ign Earth : $78 MW
- Defi Gauges for 3 meters plus controller: $1.1k ST, TC
- Mugen Thermostat, fan switch & Rad Cap + oem coolant : $400plus : MW
- Cairefresh Hepa Aircon Filter : $41 : Jimbo
- HKS Circle Earthing : $315 : GR, K'sW
- Buddy Club Spec Condenser ; $260+ SI
- Pivot Shift Light (small one) $120 GT
- Coil Amp : $300 Gary Engineering (Paya Ubi)
5) TIRES & RIMS
- Volk Racing : 17" $2560-3200 YB, LS, GR, Stamford
- Advan RS: 17" $500 - 560. YB, LS, TH
- 17" x8JJ +40 [7.9Kgs] OZ Ultraleggra: $380-430
- BBS [8.2kg P/R : $280plus : MHTS
- Prodrive GC010 17*7.5 : $2600 :SE 18' 18x8.0 $3000 (1 set)
- Bridgestone RE050 : $250 SE $220 CC
- Bridgestone GIII [215/45/17] : $230 : MHTS
- Bridgestone SO3 : $235 LS
- Bridgestone RE001 [225/45/17] : $240 : MHTS
- Toyo V-mode [215/45/17] [comfort base] : $200 : MHTS
- Falken ST 215 Semi : $195/pc : PH
- Yokohama AD07 [215/45/17] : $190/pc : PH, YB
- Pirelli P-Zero Nero : $300 LS
- goodyear eagle f1: $170
- michelin preceda (very quiet tyres) : $200
- Prodrive GC010E 17*8 : $2400; PH
- Works Wheel Nut $130 LS
- SSR 18 x 7.5 - $2400 : YB
- VR RE30 18 X 8 $3.2K - LS
6) STRUT/SWAY BARS & OTHER
- Cusco strut bar: $248 :MW
- Feels Front Strut Bar : $300+ MR
- Feel Front Carbon Strut Bar : $500+ MR
- Spoon Front Strut Bar : $260 Mikotai
- Spoon Engine Damper : $300++ MR/ST
- Comptech Rear Sway Bar $260: SI
- SPC Camber Kit for rear - $430 include alightment RV
- Feel's engine torque damper: $360 MR
- cusco front lower bar : $130 MW
- Spoon Short Shifter : $500 ST
- Neuspeed Short shifter : $110 SI
- Mugen Short Shifter : $295 YB
- Spoon Front Camber Kit: $800+ Mikotai
- Feels Steel Braided Clutch Hose : $200 SI/MR
- Feels Steel Braided Brake Hose Set : $380 : MR
- Team Kunimitsu Front & Rear Sway Bar : $800+ No install LA
- Swift Stabilizer (Tohatsu) Fornt % Rear Bar: $U/K YB
(http://www.tohatsu-springs.co.jp/stabil ... _main.html)
- Maximum Velocity crang pulley : $288 MW
- Silver's Engine Torque Damper : $ 168 MW
- SuperPro Poly Bushing (rear): $300 TL
- J's Racing front strut bar : $290 YB
- Spoon Engine Damper - $260 SG
- Spoon tower strut bar - $250 SG
- J's Racing Rear Camber Kit - S$400 MR
7) BODY KITS, LUBS & ANYTHING
- Mugen Grill : $450 : LT
- Mugen Front Bumper + Lower Air Dam : $ :
- Mugen 06' Full Bodykiy : 3k++ (Unpainted) MR
- BMW Rear Lip Spoiler : $250
- Spoon Duck Tail Spolier : $520 mikotai
- Spoon DCF Bonnet :$1,600~1800 SI
- OEM MTF-II : $55 : TS
- Amsoil 1 Carton 12 Quants : $180
- Mugen VT Pro 4l : $140
- HKS Super NA : $128 include filter and oil change GR
- HKS Spark Plug: $112 for set of 4
- Spoon Sock for brake fluid holder and steering: $28 ST
- Colgan Car Bra $350 SI
- Mugen VISOR $240 YB
- 'Chiong' Mugen Visor $100 Skull(PM)
- Ducarto Ground effector : $200 SI / YB
- NGK Sparkies [IFR7G-11KS] : $85~$90 for set of 4 :SI
- "CC Type" BJ Wiper Blades : $31 CC-SI
- Bride GIAS Sports $1750 (include seat rail,walk in price) ST
- Bride Vios full bucket seat $1360 (with Bride FO type seat rails) ST
- Bride GIAS $2100 to ??? (include seat rail) SI,ST,MR & Others
- Spoon Reservoir cover - $20 SG
- Mugen Reservoir cover - $22 SG
- Spoon Boot spoiler - $500 SG
- Spoon/Phase Front bumper - $1.8k SG
- Spoon DCF Bonnet - $1.6k SG
- Broquet Boost Master 50 - $700 - $750 Merlin (amk autopoint)
- Full Alu Radiator - $480 - SI(DX)
- Silicone Radiator Hose - $175 - SI(DX)
SI - self-import or group buy
AD - AutoDynamac - 6745 9702
CC - Chang Choon tyre & battery 68415393
GMS - Gan Motorsports - 6753 4404
GR - Garage R - 6554 4840
GT - GT Auto Sound - 6280 6636
LS - Leong Seng - 6744 4280
MR - Maximus Racing - 9856-9774
MW - McWell - 68444640
NG - New Generation - 6348 6220
PH - Poh Heng - 6456-3344
PL - Poh Lay - 6475 1990
RV - Riverview - 6481 2025 or 6481 5797
RT - Race Tech
ST - ST Powered - 6282 0330
TC - Toycar garage -
TH - Tai Huat - Ah Chuan 64537205
TS - Thian Seng (waterloo) - 3371795, 3369777
TSPL - Tye Soon Pte Ltd - 92772411 (justin)
YB - Yap Bros - 6841 2255
PJ - PhantomGT aka Johnny - 96687580
Mikotai aka Michael - 96902969
TL - Tan Lim Motors - Contact Alec 96860676
SG - steve - 96721076
Pana- 96950016
DX - DX-Performance - David Tan - 91016626
skull
UltraRacing Side Bar 4 sale (brand new)
Post by skull » Mon Jul 28, 2008 5:44 pm
i ordered direct from Ultra Racing, market price is selling at $175, im letting go at $140, installation looking at $20. Its brand new.
Side bars:
It reduces torsional stress while hard cornering. it allows it to go in and out of bends easier. Together with the lower arm bar (optional), it provides "go-kart" feel to your ride.
if you like "go-kart" feel and able to adjust your driving stlye, I would say its really quite good.
Kindly refer below for pictures. The item number is UR-SD4-392.
http://www.shc-forum.com/viewtopic.php? ... light=bars
Price are net,no bargain thks, interested pls call me at 96840621(no PM) :)
Iceman27
Post by Iceman27 » Fri Sep 05, 2008 10:15 am
My little contribution...
INTAKE + CAMS + ECU
- Cyberspeed CAI: $?? :
- Skunk 2 Cam Shafts : $ MW
- Skunk 2 Valve Springs : $ MW
- Skunk 2 Ti Retainers : $ MW
- HKS Oil Cooler Kit : $0.8k+ : GR
- KDK fan : priceless
2) EXHAUST + HEADER
- Spoon Engine Head & Gasket: 0.7k+ :mikotai
- BC V1 coilover: $1200: RT
- BC BR coilover: $1500: RT
- Honda access sport 5 way adjustable: ??
- Endless 6 Pot Calipers with rotor: $5500 : GR; Panaracer: $5200
- Spoon coilovers - $3k - SG
- Spoon brake kit - $2.6K - SG
- AP 4pot +343mm 2pc rotor+550deg pads+SSBH : $4.6 MR
- Pro tune 6 pot+330mm rotor+pads : $3300 GR
- Apexi NA timer : $180plus : Many Shops
- Max Power (Magnets) : $?? : Many shops
- VAFC2 : GT Auto
5) TIRES & RIMS
- BF Goodrich : $ :
- STP Son of a Gun all purpose cleaner - Fantastic for tyres $12.80
- Mugen : $ :
- Phase Carbon Fibre ; $ :
- Ultra Racing Rear Anti-Roll Bar (19mm) - $300 E-Rev
Key for sellers/workshops - tel numbers checked as of Apr 1 2006.
E-Rev - Richard - 91125406
RT - Race Tech
Pana- 96950016
Speed-R
Post by Speed-R » Tue Apr 07, 2009 10:25 am
INTAKE + CAMS + ECU
2) EXHAUST + HEADER
5) TIRES & RIMS
- FL CL7 HY Kit (include Paint/Front/rear add-on lips(PU material) + side skirt(Fr))-$1200 -Pana
RT - Race Tech
Pana- 96950016
-Nissan Sunny 1.5
-Mitsubishi Lancer GLX 1.6
-JDM Euro-R 2L
-Honda Odyssey Absolute 2.4L
David_Tan52
Re: UltraRacing Side Bar 4 sale (brand new)
Post by David_Tan52 » Tue Apr 07, 2009 11:04 am
skull wrote:i ordered direct from Ultra Racing, market price is selling at $175, im letting go at $140, installation looking at $20. Its brand new.
Side bars:
Reiner from CDO?
yan1261
Post by yan1261 » Sun Jun 21, 2009 11:56 pm
INTAKE + CAMS + ECU
2) EXHAUST + HEADER
- OEM Grounding + Heat Shield + CAI : http://www.goodspeed-jp.co.cc/
(I did my grounding for 70 bucks)
5) TIRES & RIMS
- Toyo R1R [215/45/17] : 4 Pieces $1080 - Yap Bros
RT - Race Tech
Pana- 96950016
3333
mikeross
Post by mikeross » Wed Mar 03, 2010 10:27 am
What could be the best tail pipe for a honda civic vtec? By the way, do they ship to the United States particularly in new york?
ckz
Post by ckz » Mon May 24, 2010 8:25 pm
INTAKE + CAMS + ECU
2) EXHAUST + HEADER
5) TIRES & RIMS
- Replica Mugen Fibreglass front Grill, Paint and Install - $250- HY
RT - Race Tech
Pana- 96950016
HY - Hui Yang (Sin Ming Auto Care) #04-02- Ivan 83336725
BlackKnight_CM5
Post by BlackKnight_CM5 » Sat May 29, 2010 11:47 am
INTAKE + CAMS + ECU
- Hurricane Stainless Steel Drop-in filter - $120 HA, AD, Merlin, RT & many others
2) EXHAUST + HEADER
5) TIRES & RIMS
- FK Massimo 5W30, 5W40 - $98 - $138 - HA
- Brisk Silver Spark Plugs - $120 - HA, AD, Merlin, RT & others
- Brisk Premium LGS Spark Plugs - $176 - HA, AD, Merlin, RT & others
RT - Race Tech
Pana- 96950016
HA - Horizon Auto (next to Tai Seng MRT) 62852883
oyjsyc
Post by oyjsyc » Tue Jul 06, 2010 2:00 pm
1) INTAKE + CAMS + ECU
- BMC CDA: $680nett : Espace (include installation, piping and hoses)
2) EXHAUST + HEADER
5) TIRES & RIMS
- Dechrome - $60 - Xquisiteworks
RT - Race Tech
Pana- 96950016
zy_w
Post by zy_w » Wed Oct 13, 2010 6:22 pm
oyjsyc wrote:1) INTAKE + CAMS + ECU
2) EXHAUST + HEADER
5) TIRES & RIMS
RT - Race Tech
Pana- 96950016
i contact Yap bros and they say they does not carry HKS exhaust..
Any one know where got lobang for HKS exhaust?
stevenhoward
Post by stevenhoward » Tue Nov 16, 2010 6:49 pm
Those are really good parts there. You have divided it from Strut/Sway Bars and the other parts really well with good price between them. I hope that things shall be well as we can choose many parts from this one.
pureness
Post by pureness » Sat Jan 29, 2011 10:41 am
would be better if you guys could post links to view the product
eg mancando http://www.mancando.com/
they have pictures to show what modifications can be done for every model
WSLBCL7
Post by WSLBCL7 » Sun Feb 27, 2011 4:29 pm
2) EXHAUST + HEADER
- D2 : $1500, AT
5) TIRES & RIMS
RT - Race Tech
Pana- 96950016
AT - AT performance 64535112 - Kelvin
Seraphblade
Post by Seraphblade » Mon May 30, 2011 9:24 pm
Received quotes recently from the following sources:
www.novaracing.com.sg (Steve Goh)
Mugen front rotor - $560
Mugen rear rotor - $480
Spoon plug cover - $200
CF trunk with lip - $950+
King Crimson (Mugen distributor in SG)
Mugen Oil Filler Cap..............................S$ 130.00
Mugen Radiator Cap..............................S$ 52.00
Mugen Aluminium Radiator.....................S$ 2,380.00
Mugen Ignition Coil Cover......................S$ 599.00
Mugen Low Temperature Thermostat.....S$ 145.00
Mugen Thermo Switch...........................S$ 84.00
Mugen High Performance Oil Filter........S$ 50.00
Mugen Short Shifter................................S$ 370.00
Mugen Front Aero Bumper.......................S$ 2,000.00
Ex: Honda Civic SiR (EK4) > Hyundai Avante
Current : Honda Accord Euro-R (CL7R) > BMW 328i (F30)
