Installed the Pioneer DMH-Z6350BT recently and as part of the install, the unit came with a long USB cable. I hadn't checked properly and didn't noticed until after the install, that the two USB Ports in the Honda City (2017) was disabled. I found it strange that instead of hooking up the existing USB ports to the Pioneer, the installer used the original USB cable. TO be sure it is rather unsightly with the cable running out from the glove compartment.
So hoping someone would be clarify and help advise:
1) Can't both USB ports be connected to this DMH-Z6350BT ?
2) If not, I am assuming that ONE would be able to connected to the DMH-Z6350BT.
At worst case, I am thinking of hooking 1 USB port to the DMH-Z6350BT USB port and the second to provide only power.
Many thanks in advance for your expert advise.
