Selling a set of Audiofrog GS series 3-way speakers with customized Honda Stream A-pillars. Please check out my item in carousell by clicking the below link.
https://sg.carousell.com/p/203201662
Audiofrog offers a 1″ fabric dome tweeter (GS10) for smooth highs and it matches well with your choice of a 4″ (GS40) or a 6″ (GS60) premium midrange with propylene cone and a non-resonant ABS/Fiberglass basket. They feature a custom-designed and tuned passive crossover available for each mid/tweet combo to ensure a smooth transition between speakers. You can even use all three by using the 6″ driver (GS60) as a midbass with an active crossover and dedicated amplifier. The GS60 is optimized for use in passive systems with the GS10 tweeter. It can also be used in active systems or in a three-way system with the GS10 and GS40. For a combination of active and passive three-way system, use the GS60 with the GS10, GS40 and GS410C.
GS10 1″ (25MM) PREMIUM TWEETER
FEATURES
1″ (25 mm) fabric dome
1″ (25 mm) voice coil on aluminum former
Ferrofluid-filled gap for superior heat dissipation and increased damping at resonance
Neodymium motor with copper pole piece cap
Bucking magnet for increased sensitivity
Reflection-absorbing and diffusing foam pad under diaphragm for smooth frequency response
Screw terminals
GS40 4″ (100MM) PREMIUM MIDRANGE SPEAKER
FEATURES
Proprietary injection molded mented ABS and fiberglass basket
1″ (25mm) copper voice coil on Kapton® former
Ferrite motor with neodymium bucking magnet for increased sensitivity
Parabolic propylene cone
Nitrile butadiene rubber surround
Flat progressive Nomex® spider
Fast-on terminals secured with integrated PC board
Grilles included
GS60 6″ (165MM) PREMIUM MIDBASS SPEAKER
FEATURES
Proprietary injection molded vented ABS and fiberglass basket
Ferrite motor with extended polepiece for magnetic field symmetry
Grilles and multiadaptor included
GS410C PREMIUM GRADE PASSIVE CROSSOVER NETWORK
Specifications
Nominal Impedance: 4 Ω
RMS Power Handling: 70 W (system)
Peak Power Handling: 200 W (system)
Frequency Response: 90 Hz – 20 kHz (system)
Crossover Frequency: 4.2 kHz
Low Pass Filter: 3rd Order Acoustic
High Pass Filter: 3rd Order Acoustic
Recommended Amplifier RMS Power Range: 15 W – 75 W
