WTS:Exedy Hypersingle Clutch used with BNIB repad/disc
For selling of any personal new / used car related or non automotive stuff here
YH
Post by YH » Thu Jul 28, 2016 7:06 pm
For K series engines with manual 6 speed gear box (DC5, EuroR, FD2R, FN2R etc)
As mentioned in the title
http://www.exedy-racing.com/racing/en/p ... ingle.html
http://shop.exedyusa.com/exedy-racing-c ... 34513.aspx
The original clutch kit was used for a year for about 15K-20K
Removed from car when I upgraded to a carbon clutch
I bought the new repad or the replacement disc from Japan thinking that I might have to use it again when my carbon clutch wears out.
Do take note that this clutch has NEVER been repad before
Plans have changed and this is now not needed, even as a spare clutch.
The whole clutch kit (pressure plate, original disc and flywheel) AND the BNIB replacement disc/repad for JUST $500
Price is firm. The repad itself is nearly $400 new. If you bring the clutch kit to an experience workshop, they will even tell you that the original disc still has plenty of life in it
So for $500, you are essentially getting a 80-90% new clutch kit that sells for 1.5K new. The only thing you need to buy for this is the clutch bearing (which most reputable workshops will carry anyway)
If you are keen and if the price is agreeable with you, please PM me you contact and I will get back to you asap.
Cheers!
YH
Re: WTS:Exedy Hypersingle Clutch used with BNIB repad/disc
Post by YH » Thu Jul 28, 2016 7:29 pm
Oh yes, in case you are curious...
NO ice cream van sound
YH
Post by YH » Tue Aug 30, 2016 12:25 pm
Bump to the top!
YH
Post by YH » Thu Sep 15, 2016 5:44 pm
Mid Autumn festival bump!!
hondaa
Post by hondaa » Wed Sep 21, 2016 12:43 am
upz and refresh this post for my brother. This set of clutch is sure worth to purchase!!!!
terroz
Post by terroz » Wed Sep 21, 2016 10:17 am
How is the stiffness compared to the stock clutch?
YH
Post by YH » Wed Sep 21, 2016 11:19 am
Won't lie to you. It's definitely stiffer, around the same pressure as orgura
If your engine is built or modified, and if you can't stand the ice-cream van sound, this is a good alternative to ORC
If your engine is stock, then I would suggest you just get the stock clutch
terroz wrote:How is the stiffness compared to the stock clutch?
hondaa
Post by hondaa » Wed Sep 21, 2016 4:20 pm
It's abit stiff but once bolt on k20a or k20a3. It brings out your true engine power. I'm using same model of clutch for almost 9 years and I never look back on stock clutch since. For keen buyer's info if its unknown...this set of clutch is actually the same as toda racing and Js racing clutch. They tag their own brand's name after direct purchase from exedy. The replacement exedy clutch pad can be use on either this 3 sets of clutch.
YH
Post by YH » Wed Sep 21, 2016 6:34 pm
thank you for the information brother!
Much appreciated!!
YH
Post by YH » Thu Sep 29, 2016 3:37 pm
Bump to the top!!
