Selling a local warranty set of DLS Reference CC-44 - 4 x 110 Watt Amplifier, I still have the original box and the amplifier is very new and close to BNIB condition.
Reason for selling is because I have upgraded my ICE setup with another DSP based amplifier.
Retail selling price for this amp is around $1100. Willing to let go if interested buyer is willing to offer a reasonable pricing. Do PM me your offer price.
Specifications
Number of channels 4
Amplifier class AB
Output power in 2 ohm 4 x 110 Watt
Output power in 4 ohm 4 x 85 Watt
Mono bridge mode 4 ohm 2 x 220 Watt
Damping factor >300
S/N ratio, A-weighted >110 dB
Frequency range 10 Hz - 60 kHz
Input sensitivity 1 - 4 Volt
Input impedance 6 kohm
Input impedance, high level 45 ohm
High level input with auto start Yes
Remote bass level control No
Low level output No
Remote phase shift control No
Filters channel A & B HP 50 - 500 Hz, LP 50 - 500 Hz
Filters channel C & D HP 50 - 500 Hz, LP 50 - 500 Hz
Power consumption (idle) 0,7 A
Power consumption (max) 64 A
Rec. power cable 16 sq mm ( 5 AWG)
Fuses use external fuse
Dimension (W x D x H) 129 x 320 x 55 mm (5,07" x 9,85" x 2,16")
Weight 2,4 kg
WTS: DLS Reference CC-44 - 4 x 110 Watt Amplifier
Re: WTS: DLS Reference CC-44 - 4 x 110 Watt Amplifier
Pricing is negotiable. Do offer a price if you are interested.
