Poor fc
New Civic model year 2006 onwards
Clement ong
Poor fc
Post by Clement ong » Tue Oct 20, 2015 11:21 am
Hi lao jiaos,
I recently bought a 08 nov fd1. After three pumps i am getting roughly 8km/litre. Can i check if this is normal?
Stock setup with 18" rims. Pumped both 8000 and 5000 essso
rewrewss
Re: Poor fc
Post by rewrewss » Wed Oct 28, 2015 2:27 pm
same here
Clement ong
Re: Poor fc
Post by Clement ong » Wed Oct 28, 2015 10:30 pm
any lao jiao care to share some ideas? my last tank has improved to 9km/litre
king01sg
Re: Poor fc
Post by king01sg » Fri Oct 30, 2015 10:19 pm
downgrade to 16 inch
Clement ong
Re: Poor fc
Post by Clement ong » Sun Nov 01, 2015 8:51 am
thanks for reply, i just downgraded to 17" let's see how it goes :)
LMG
Re: Poor fc
Post by LMG » Sun Nov 01, 2015 8:56 am
Thumbs upz.. look fwd to ur update..
Sent from my GT-I9100 using Tapatalk
Avenged
Re: Poor fc
Post by Avenged » Tue Nov 03, 2015 7:03 pm
Hey bro. 18-inch rims can be quite bad for FC. Downgrading to 17s are a good idea as they will still give you a very nice look if you get them in the right specs. You may also want to consider getting genuine, lightweight 17s (i.e. made from a lightweight material) for even better FC.
You might also want to check out these things just in case:
Wheel alignment
Improper wheel alignment (camber degree and toe angle) can negatively affect FC because you are setting the car up for less contact on the ground (camber) or setting the wheels up to go in opposing directions (toe).
ECU
The ECU may have been tuned/re-flashed for a modified engine or intake/exhaust system. If so, your AFR (air-fuel ratio) will be wrong for a stock set-up. This may cause excessive fuel injection or other similar problems.
Worn engine components or leaking intake/exhaust
Too many possibilities to quickly list, but basically a whole host of factors here can affect FC. For instance, worn spark plugs, injectors, or maybe leaking gaskets, intake/exhaust manifold etc.
Damaged brakes
If your brake seals are damaged, your brakes may not be releasing enough after clamping, and in effect you are constantly, partially braking even when driving.
These are just some suggestions off the top of my head. You'll have to go to a good workshop like SKM to diagnose better. I'm actually running into some FC problems myself too and will probably go check it out... Lol.
Clement ong
Re: Poor fc
Post by Clement ong » Wed Nov 04, 2015 9:08 am
Wah bro, very detailed help there. Appreciate it!
My plugs are still healthy so let's see how it goes. Latest pump is 9.5km/litres haha
Do update us on ur check too haha
king01sg
Re: Poor fc
Post by king01sg » Wed Nov 04, 2015 12:26 pm
clement! change car from vios to civic! siao siao!
Clement ong
Re: Poor fc
Post by Clement ong » Wed Nov 04, 2015 5:39 pm
Wahhhh who is this? How you know i changed from vios?
Chloe8
Re: Poor fc
Post by Chloe8 » Mon Nov 16, 2015 12:39 pm
am on FD2 and clocked 378km for my first full tank.
yet to do a new servicing and any other checks.
Clement ong
Re: Poor fc
Post by Clement ong » Tue Nov 17, 2015 9:17 pm
You just got your fd2 too? Fc like same not very good hor haha
king01sg
Re: Poor fc
Post by king01sg » Tue Nov 17, 2015 9:46 pm
Clement ong wrote:You just got your fd2 too? Fc like same not very good hor haha
my is 1.8m only :( is fd1
Omantay
Re: Poor fc
Post by Omantay » Tue Nov 07, 2017 1:00 pm
ex FD2R owner ( 10.9km / Litre )
Best Regards
Cliff Tay aka Omantay
Straight road is for fast car.....Corner is for fast driver
Chloe8
Re: Poor fc
Post by Chloe8 » Thu Nov 09, 2017 12:49 am
i hit 480 last week. foot seems lighter nowadays :lol:
