B series i am confused
Hey guys i am new to the forum. I would like to know what is changed when the engine is swapped from a b16a to a b20b engine? Which parts and changed?
Re: B series i am confused
Essentially, the engine block, which is the lower half of the engine. That being said, some other parts need to be changed as well, for e.g., the exhaust manifold (if it does not clear the extended length of the larger engine block).
hope that answers your question!
Hey thanks man decided to just overhaul my engine haha too troublesome to swap and its illegal anywaypornopyro wrote:Essentially, the engine block, which is the lower half of the engine. That being said, some other parts need to be changed as well, for e.g., the exhaust manifold (if it does not clear the extended length of the larger engine block).
Hahaha... No problem! Good choice, stock is good.
Hahaha somethings are best left unsaid man haha. By is there any ek on sg road with approved turbo?pornopyro wrote:Hahaha... No problem! Good choice, stock is good.
