water leaking through tail light gaskets
philipho
Post by philipho » Sat May 02, 2015 11:46 pm
Whenever it rains a small puddle of water will form at the spare tyre area
I did some read up and it seems that my tail light gaskets have hardened over time allowing water to seep through, which is a common issue for integras.
Does anyone know where I can fix the seals?
holysniper
Re: water leaking through tail light gaskets
Post by holysniper » Mon Jun 15, 2015 6:13 pm
philipho wrote:Hi,
Hi Bro,
Have you found any place which sells the taillight gasket? I have checked with Thian seng and they do not have stock.
What I did is just stick up the back of the gasket and it seals up fine. :oops:
Thanks! :)
philipho
Post by philipho » Mon Jun 15, 2015 9:40 pm
Kah motor sells the gasket, but they require you to go down personally to order from them.
I managed to fix the leak by removing the bumper + tail lights, cleaning the dirt and applying a layer of silicon on the gaskets.
holyturtle
Post by holyturtle » Sun Aug 02, 2015 9:26 pm
The most common and perm fix is to drill a hole in the tailights. the fishtank effect will come back no matter how you fix it
STRATUS
Post by STRATUS » Mon Aug 17, 2015 2:36 pm
HAHAH yup thats what I did for mine as well. drill 2 holes in each corner of each taillight.
Bad design is the issue. Even NSXs had this problem........
