Crossroad Suspension Loose Feeling
Home Of The CrossroadeRs
Kev10
Post by Kev10 » Sun Apr 19, 2015 12:17 am
Hi Fellow XRDs
Just want to share a problem that you might be experiencing as well. My ride is coming to 6 years now and lately I am starting to feel like the rear is feeling loose especially when I go over bumps. I changed a new set of dampers but the feeling is still there.
I consulted my workshop and they told me that one of the rear suspension arm bushings were loose and suggested that I change both sides. I have ordered them from TS and should be getting them soon.
Just want to check if anyone else experiencing this and if you have also changed out any other bushings. I am not sure if the manual calls for replacement of any bushings at a certain mileage but do share if there are other bushings I should also be replacing.
Below is the image of the bushing (it's the one that is replaceable).
Crossroad Rear Suspension Arm Bushing.jpg (36.59 KiB) Viewed 2891 times
Kev
frenzs
Re: Crossroad Suspension Loose Feeling
Post by frenzs » Mon Apr 27, 2015 9:47 am
Thanks for the heads up.
Mine is 7 years and on normal road is ok, but like you say on bumps can feel it.
Appreciate your update on the cost of parts and service so I can consider doing it too.
Again, Thanks.
