New to crossroad
Home Of The CrossroadeRs
Cephas021
New to crossroad
Post by Cephas021 » Sun Nov 16, 2014 8:34 am
Hi guys, just got a second hand crossroad yr 09. Any advise what to look out for ?
And appreciate if any could help answer my following queries
1) can the reverse sensors sound be lowered ? Currently it'sreally too loud
2) after turning ignition off there is a eeeee sound normal?
3) I hear sounds on and off while going over humps or uneven ground wonder if it the susspension?
4) the ride is quite bouncy is it normal or my tyre pressure is set wrong currently at 220
Thanks all in advance for the reply
Cephas021
Post by Cephas021 » Sun Nov 16, 2014 10:21 am
Also what's the average FC like? Mine is all stock
BB88WA
Post by BB88WA » Mon Nov 24, 2014 11:41 pm
Welcome to the club..
Reverse sensor can be lowered but depending on what kind of sensor it is.. check w an audio shop that does reverse sensor.. they should be able to advise ..
The eee sound should be the ignition coil or something like that.. shouldn't be an issue but check w a mechanic just in case..
The car ride pretty hard.. The noise is normal and the bumps are normal too.. I also hate it.. but not sure if there are comfortable suspension for the xrd. . Other bros here may know..
FC averages 11.5km/l
If mostly highway.. can get 12+..
If it's mixed 50/50.. I average only 10.2km/l
Have fun.. its a lively car that stands out. We don't know what to change to when the time comes.. gonna be a tough decision.. :-)
neonleon
Post by neonleon » Wed Nov 26, 2014 11:35 am
Is your door opened when turning ignition off n left the key there?
michael_hots
Post by michael_hots » Wed Nov 26, 2014 10:11 pm
Hv recently replace my leaking shocks to silvers coilovers..quite comfy and very stable i would say compared to stock ones...
neonleon
Post by neonleon » Sat Nov 29, 2014 11:13 pm
michael_hots wrote:Hv recently replace my leaking shocks to silvers coilovers..quite comfy and very stable i would say compared to stock ones...
got pict to share? what's teh damage?
michael_hots
Post by michael_hots » Mon Dec 01, 2014 7:38 am
Got it done at 1300...
neonleon
Post by neonleon » Tue Dec 02, 2014 11:43 am
sounds good.
may i know where was this done?
michael_hots
Post by michael_hots » Wed Dec 03, 2014 1:03 pm
neonleon wrote:
michael_hots wrote:
neonleon wrote: got pict to share? what's teh damage?
sounds good.
Got them at mcwell at paya ubi..
neonleon
Post by neonleon » Thu Dec 04, 2014 1:44 pm
Thanks will check it out.
Cephas021
Re: New to crossroad
Post by Cephas021 » Fri Dec 05, 2014 3:01 pm
Cephas021 wrote:Hi guys, just got a second hand crossroad yr 09. Any advise what to look out for ?
Got that fixed by the audio shop by taping a tape over the speaker in the rear :)
I suspect its the door locking gears, cuz it happens when i put the gear to park or when i unlock the door in the car, any idea where to get it fixed ?
The mech checked the susspension, said there is no leak but i always hear squeaking sounds, mech suggested may be the mounting ... -.-
This problem i figured no choice getting used to it now lol
Cephas021
Post by Cephas021 » Fri Dec 05, 2014 3:04 pm
My Fc is like 8 - 9km :( pretty bad when i dont hit the highways but i find my throttle reponse is very sluggish like very underpowered...... thinking of getting the throttle body cleaned this sat wonder will it helps
neonleon
Post by neonleon » Tue Dec 09, 2014 12:27 pm
Beep beep beep, beep beep beep ...= key in ignition reminder. ignition off, door open.
Beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee....eep= lights on reminder. ignition key out, door open.
michael_hots
Post by michael_hots » Mon Jan 05, 2015 8:03 pm
Hi guys, im dekitting as itchy to get another ride soon..do look up at sales thread if keen ya....thanks!
Cephas021
Steering feels heavy
Post by Cephas021 » Thu Jan 08, 2015 2:45 pm
Can anyone help? I remember when I first got the XRD the steering was very light almost like can use 2 fingers to turn the steering. However recently there are some problems so after checking the steering rack was a issue but after that the steering becomes very heavy ask mech he say it's normal so it's it normal?
