Steering wheel vibrate
Posted: Wed Nov 05, 2014 2:02 am
by jenson
Hi all, my ride steering wheel vibrate when brake is apply , anyone can advise what is the problem?
Posted: Wed Nov 05, 2014 11:10 am
by cyeric81
Most probably is brake disc uneven n need to skim already.
Posted: Wed Nov 05, 2014 11:19 am
by jenson
Thanks bro,
I was told that need to change the rotor
Posted: Sun Nov 09, 2014 10:36 pm
by MCDS
yup. either brake pad kaput or rotor kaput. NEED to change else you cannot modulate your speed NOR stop when emergency...
don't delay with brakes. do it immediately. ALSO MUST change new brake fluids and pads if you can. these 3 items don't use back already.
workshop say no need you can change workshop already - they let you have lousy brakes and higher potential business later.
brake fluids specify MUST be dot4 or dot5.1 if you on stainless steel braided brake hoses. if rubber hose just use dot4.
DO NOT USE DOT3. YOU WILL regret when shit happens.
ok enough koloso... you decide ba... your car, your money, your life. just don't take other's lives with you ok?
