1. 16 chrome McGard Splinedrive lock lug nuts with adaptor, plus 4 special "flower" shaped lock nuts with adaptor
pitch m12 x 1.5mm, suitable for honda, toyota, mitsubishi
not suitable for subaru, nissan & suzuki models - $200 c&c
http://s968.photobucket.com/user/kualah ... ort=3&o=35
http://s968.photobucket.com/user/kualah ... ort=3&o=34
http://s968.photobucket.com/user/kualah ... ort=3&o=33
http://www.mcgard.com/part-search/produ ... -and-1-key
http://www.mcgard.com/part-search/produ ... ation-tool
2.
- TRD emblems,approximately 1cm by 5cm by 1mm(thickness) with double sided tape - $2/pc
3. Carlube Oil Treatment 300ml - $2, unopened
Uses: Reduces engine oil use, Increases engine oil protection, Reduces carbon deposits
http://s968.photobucket.com/user/kualah ... ort=3&o=18
4. Original Bride Stradia Sports fully reclinable seat(silver glittery backing),comes with Vios double locking railings - $500 cash & carry
5. 8 point voltage stabiliser( brand is Jinke) - $20 cash & carry
Non car items:
1. handphone dust cover plugs, 4 assorted designs - $2 each
http://s968.photobucket.com/user/kualah ... ort=3&o=26
http://s968.photobucket.com/user/kualah ... ort=3&o=25
http://s968.photobucket.com/user/kualah ... ort=3&o=24
http://s968.photobucket.com/user/kualah ... ort=3&o=21
http://s968.photobucket.com/user/kualah ... ort=3&o=22
http://s968.photobucket.com/user/kualah ... ort=3&o=23
2. Original Paul Frank bulky iphone4/4S casing - $5 (BNIB & still in original packaging)
http://s968.photobucket.com/user/kualah ... ort=3&o=19
http://s968.photobucket.com/user/kualah ... ort=3&o=20
3. Original "MyMelody" iphone 4/4S casing - $5 (BNIB & still in original packaging)
4. FCUK ( French Connection of U.K) dress watch, bought for $188, selling for only $50!
item is brand new, comes with box. model no. FC1113BW
http://s968.photobucket.com/user/kualah ... sort=3&o=3
http://s968.photobucket.com/user/kualah ... sort=3&o=4
http://s968.photobucket.com/user/kualah ... sort=3&o=6
http://s968.photobucket.com/user/kualah ... sort=3&o=5
5. Prolink Hurricane 9000C ADSL Ethernet Modem, brand new - $10
Features
The Prolink Hurricane 9000 is an Ethernet ADSL Bridge/Router which fully complies to ANSI T1.413 Issue 2, ITU-T G.992.1 (G.dmt) and G.992.2 (G.lite) ADSL standards. It supports Full-Rate ADSL transmission at up to 8Mbps downstream and up to 1Mbps upstream. It can be connected to a small, home-office LAN or a single Ethernet-equipped PC to provide broadband services to a single/multi-user environment with support both Static and Dynamic IP Routing, Network Address Translation and Dynamic Host Configuration Protocol Server.
Specifications
ADSL Compliance
Compliant with ADSL standards
Full-rate ANSI T1.413 Issue 2 and ITU G.dmt (G.992.1) standards
Splitterless ITU G.lite (G.992.2) specification
ADSL over POTS (Annex A) and ADSL over ISDN (Annex B)
DMT modulation and demodulation
Full-rate adaptive modem
Maximum downstream rate of 8 Mbps
Maximum upstream rate of 1 Mbps
Tone detection for low power mode
Supports splitterless ADSL implementation
Supports Dying Gasp
ATM Protocols
WAN mode support: PPP over ATM (RFC 2364) and PPP overEthernet(RFC2516)
LAN mode support: bridged/routed Ethernet over ATM (RFC1483) and Classical IP over ATM (RFC 1577)
ATM Forum UNI 3.1/4.0 PVC
Up to 8 VCs (Virtual Circuits)
ATM SAR (Segmentation and Reassembly)
ATM AAL5 (Adaption Layer type 5)
OAM F4/F5
Bridge Mode
Ethernet to ADSL self-learning Transparent Bridging (IEEE 802.1D)
Supports up to 128 MAC learning addresses
Router Mode
IP routing&RIPv2
Static routing
DHCP (Dynamic Host Configuration Protocol) Server and Client
NAPT (Network Address and Port Translation)
NAT (Network Address Translation)
ICMP (Internet Control Message Protocol)
Simultaneous USB and Ethernet operation
Security
User authentication for PPP
PAP (Password Authentication Protocol)
CHAP (Challenge Authentication Protocol)
Password protected system management
Ethernet interface
Compliant with IEEE 802.3 standard
10/100 Mbps auto selection
MDI/MDIX Autosensing
USB host interface
Compliant with USB Specification, Revision 1.1
USB full speed (12 Mbps)
HTTP Web-based management
Firmware upgrade via FTP
WAN and LAN side connection statistics
Configuration of static routes and Routing table
Configuration of NAT/NAPT
Password protected access (Admin/User)
Selection of Bridge or Router Mode
PPP user ID and password
Configuration of VCs (Virtual Circuits)
This Package contents
One Hurricane 9000 ADSL Modem/Router
One RJ-45 straight cable
One RJ-11 telephone cable
One USB cable
12V Power Adaptor
Manual and CD
External Connectors
Power Switch
Power Connector
Reset Button
1 x RJ45 LAN Connector
1 x USB Connector
1 x RJ11 Connector
LED Indicators
Power LED
Link LED
TX/RX LED
LAN LED
Whatsapp or call 91807908 to deal!
WTS: car & non car items!
