What tyre u have changed lately?
Waterbottle
Post by Waterbottle » Tue May 27, 2014 10:44 pm
It's time to prep for tyre change.
Previously using AD08 and there's a new AD08R out replacing the latter. After reading reviews, it seem tat wet traction is not good.
Am looking to use Bridgestone again, RE11A, RE070. Has anyone bought the RE55S?
Care to share your opinions? Thanks.
I'm back with a vengenance....
Teow Yiwei
Post by Teow Yiwei » Wed May 28, 2014 9:04 am
using PSS now. not bad.
Waterbottle
Post by Waterbottle » Wed May 28, 2014 9:32 am
Teow Yiwei wrote:using PSS now. not bad.
[img]so how much u bought?
Wat tyres were u on prior to PSS? Thanks[/img]
Teow Yiwei
Post by Teow Yiwei » Wed May 28, 2014 12:28 pm
pss 215/45/17 i bought at $250/pc. but thats > 1 year old tyre but brand new la.
Prior to this was using the stock RE050.
zhihong
Post by zhihong » Thu May 29, 2014 6:58 pm
Potenza RE070....!
Previously on RS3, S001, AD07, but I still went back RE070...! Best
puffer71
Re: What tyre u have changed lately?
Post by puffer71 » Thu May 29, 2014 8:03 pm
Waterbottle wrote:It's time to prep for tyre change.
Bro, I used the RE55S years ago for track. It's really good. Wet grip is bad though. For sepang, it's best to use SR2 compound as the road temp is very high. I think Bridgestone has discontinued this tyre. Check for year of manufacture before buying.
Anyway, I'm just bought RE11S couple of months ago. Great for wet roads. I used to use RE11 years ago and won the street class time attack.
Cheers.
Waterbottle
Post by Waterbottle » Thu May 29, 2014 8:37 pm
Cheers.
Ya. I did some research and RE11S replaces the 55S. Strangely the reviews for 55S all point to wet is poor. But 11S which replaces the 55 has good wet traction. Btw how much you bought the 11S? Is it noisy? I called up a tyre shop today but said never heard of 11S.
Waterbottle
Post by Waterbottle » Thu May 29, 2014 8:42 pm
zhihong wrote:Potenza RE070....!
when's the most recent purchase? $300+?[/list]
-=[Yamaha R1]=-
Post by -=[Yamaha R1]=- » Fri May 30, 2014 1:06 pm
Bought Re070 in feb. 225/45/17 at $220 per pcs. AL tyres.
If It Ain't Scary, It Ain't Fast Enough..
scratchyz
Post by scratchyz » Fri May 30, 2014 2:43 pm
changed to ad08r around $240 a piece....dry grip pretty good, wet normal i feel average...when rain i usually drive much slower..
re070 still better i feel for the harder side wall...
Waterbottle
Post by Waterbottle » Fri May 30, 2014 9:24 pm
ad08r cheaper than 08? That's gd. Thanks for the info bro.
Waterbottle
Post by Waterbottle » Fri May 30, 2014 9:30 pm
-=[Yamaha R1]=- wrote:Bought Re070 in feb. 225/45/17 at $220 per pcs. AL tyres.
thanks for info bro..
scratchyz
Post by scratchyz » Fri May 30, 2014 10:17 pm
changed it at leong seng at that price so i am sure outside small shop should be cheaper....cheers
puffer71
Post by puffer71 » Fri May 30, 2014 10:42 pm
Cheers.
Bro, my mistake. I just bought the RE11a, not the RE11S. RE11S is a semi slick tyre successor to RE55S.
zhihong
Post by zhihong » Sat May 31, 2014 6:54 pm
Good deal. Was quoted $330/pc from Cheng Jin @ kaki bukit.
