Folding Mirror Problem
Home Of The CrossroadeRs
Kev10
Post by Kev10 » Fri May 23, 2014 5:56 pm
Hey Fellow XRDs
I started getting this problem where my folding mirror is folding slower than usual. the left side seems to fold normally but the right side takes twice as long.
Anyone had this issue before? Appreciate if you can share if there is a quick fix. Not sure if I can just open it up and spray WD40.
Thanks in advance for any advice.
Kev
neonleon
Re: Folding Mirror Problem
Post by neonleon » Mon May 26, 2014 8:03 pm
Kev10 wrote:Hey Fellow XRDs
Kev
See whats inside first. You can pull the mirror out from casing easily. Use a torchlight to see whats inside. If there is dirt or grass or spider web clean it. Or loose or broken part N re fix back after that.
tsia
Post by tsia » Mon May 26, 2014 10:41 pm
I'm using my second set and it die so didn't change it again. Cost is 400
neonleon
Post by neonleon » Tue May 27, 2014 9:32 am
tsia wrote:I'm using my second set and it die so didn't change it again. Cost is 400
Sibeh expensive.... :shock:
frenzs
Post by frenzs » Tue May 27, 2014 11:47 pm
Maybe you can use the first set parts on the second set.
Kev10
Post by Kev10 » Sat Sep 13, 2014 10:38 pm
Thanks for the advice all. I went back to KAH Motor Mandai and they sprayed the side that was slow with some grease and it helped a little. Now the other side, that didn't have any problems initially, has died, go figure... Guess I will have to get it replaced.
casper1437
Post by casper1437 » Tue Aug 01, 2017 10:10 am
Kev
Hey bro, mind you share how did you open the casing of the side mirror. One of my side mirror seem doesn't stop when upfolding and totally flip maximum outward. I try to open the casing but seem no luck at all. Thank in advance.
neonleon
Post by neonleon » Mon Oct 16, 2017 2:42 pm
Pull the mirror piece out.
