Air Con Leakage
Scbb
Air Con Leakage
Post by Scbb » Tue Mar 25, 2014 4:56 pm
My aircon was blowing hot air on the driver side and minimal cool air on the passenger side. Went to top up gas just now (cost me $20) and the guy at the workshop says there might be a leak. Need to monitor for 1 week after gas top up. If warm air comes back again, it's definitely a leakage.
Any trusted workshop to introduce to check and fix the air con? Roughly how much does it cost?
SpeedMaster1979
Re: Air Con Leakage
Post by SpeedMaster1979 » Wed Mar 26, 2014 1:19 am
Scbb wrote:My aircon was blowing hot air on the driver side and minimal cool air on the passenger side. Went to top up gas just now (cost me $20) and the guy at the workshop says there might be a leak. Need to monitor for 1 week after gas top up. If warm air comes back again, it's definitely a leakage.
You can go to Fong Huat Aircon(AMK Autopoint) OR Markcool(Woodlands area)to do a check,
Cheers!
Speed is nothing without control
fEi-
Post by fEi- » Wed Mar 26, 2014 9:49 pm
check it out fast bro, before more things start breaking down..
for your case, it may be as small as fan motor faulty to compressor ba.. imho
scratchyz
Re: Air Con Leakage
Post by scratchyz » Wed Mar 26, 2014 10:42 pm
had a leakage before with similar symptoms...went ah heng to change the pipe which was leaking..100 plus
calvin_
Post by calvin_ » Wed Mar 26, 2014 11:09 pm
same symptoms for mine. it was a pipe leakage.
was told the original pipe is 250.
i went for the non-original one. with labour it was about 160 irrc.
i fixed mine at riverview auto. at amk autopoint.
Treat a car like a human. It needs healthy diet, care and grooming, and most importantly, exercise.
redliverpool
Post by redliverpool » Mon Apr 07, 2014 11:38 pm
same for mine. Condenser cracked and replaced. $280
Waterbottle
Post by Waterbottle » Sat Sep 27, 2014 10:28 am
calvin_ wrote:same symptoms for mine. it was a pipe leakage.
My ride is Feb 07. Also encountered same issue. Driver side intermittently blow hot/warm air. Now at mark cool. Worker found the black rubber hose the feeds to the compressor leaking. Another pipe that connects to the top left part of engine bay has a worn out ring seal.
Currently repairing. Quoted price $128.
I'm back with a vengenance....
