Thread on the bolts had worn out
paxidorm
Post by paxidorm » Tue Apr 30, 2013 8:05 pm
Hi, I realised the thread on the bolts used to tighten the engine cover had worn out. Anyone know whether it is easy to get them replaced?
cl7teckie
Post by cl7teckie » Fri May 03, 2013 2:57 pm
if it is simple bolt, lots of OEM screw/bolt shop. If it is unique, just order it thru KM lor.
funkychicken
Post by funkychicken » Wed May 08, 2013 1:48 am
Go to kelang an lane. There is this stretch of shop. One of the shop selling screws only. Jus show them the sample. Gd luck.
funkychicken
Go to kelantan lane. There is this stretch of shop. One of the shop selling screws only. Jus show them the sample. Gd luck.
paxidorm
Post by paxidorm » Wed May 08, 2013 8:12 am
Hmm...The bolts I am referring to are mounted into the engine. Only the nuts could be removed whenever taking out the engine top cover.
funkychicken
Post by funkychicken » Tue May 21, 2013 5:05 pm
Ohhh thengo to honda stockist or other alternative aftermarket ones like ARP very popular amongst those who rebuilt their engines.
funkychicken
Post by funkychicken » Tue May 21, 2013 5:08 pm
Cheaper alternative buy the die tap to rethread ur bolt threads. Avail at most diy shop.
