Questions re oil coolers on CL7R
charcoalx
Post by charcoalx » Mon Mar 25, 2013 2:32 pm
Would like to consult all those bros running oil coolers on their EuroRs.
I previously installed a Works cooler with custom lines and there is an obvious low whining sound when driving. Ah Heng (SKM) told me all CL7Rs with oil coolers installed will more or less have this type of sound.
1. What oil coolers are you using?
2. Do you experience a 'whining' sound when you step on the accelerator?
coldspark
Post by coldspark » Mon Mar 25, 2013 3:09 pm
i am on works oil cooler as well.
Getting used to the whining sound already.. haha.
Electricity is actually made up of extremely tiny particles called electrons, that you cannot see with the naked eye unless you have been drinking...
charcoalx
Post by charcoalx » Mon Mar 25, 2013 3:34 pm
coldspark wrote:i am on works oil cooler as well.
Its damn irritating. I removed my Works oil cooler already due to this.
Anyone on the Earls oil cooler kit? Any sound on that one?
scratchyz
Post by scratchyz » Mon Mar 25, 2013 7:29 pm
It is due to the balancing shaft which is built into the euro r oil pump
Change it to the fd2r oil pump will eliminate the sound... Advisable to do this if u track often cause the balancing shaft is prone to seizure are many track days... Can go read up on the internet
RacingMiku
Post by RacingMiku » Mon Mar 25, 2013 7:51 pm
Am using Earl's oil cooler. No whining sound for me.
