power steering fluid level drop
Posted: Wed Feb 20, 2013 1:02 am
by klt
my cp1 power steering fluid in the reservoir drop to below min level and i can see traces of the fluid on my rubber boot of the drive shaft. any bro having this problem? is my power steering pump going to kapootzz?
YES
Posted: Sun Feb 24, 2013 10:38 am
by richcel313
Yes bro, I think you better get it fixed. My 5yrs old ride just fixed this issue, I guess it a common wear and tear problem for CP1. Luckily is one of those minor issue.
Posted: Sun Feb 24, 2013 4:22 pm
by maskedrider
PS pump needs to change, prepare 1k for Kah motor for 3 items
Hope this help
Posted: Mon Feb 25, 2013 5:28 pm
by klt
Bro richcel, Kah motor told me both the pump and power steering rack are leaking. Was just quoted by them SGD2470 for both parts and labour.
Did you change both as well?
Posted: Tue Feb 26, 2013 9:52 pm
by richcel313
no, mine is only pump leak,i only get the repair kit to fix the PS pump which cost approx 100+. ah heng fix it for me.
Posted: Sat Mar 02, 2013 9:55 am
by klt
I'll be changing the power steering pump repair kit as well. Was quoted about S$200 for parts and labour by an outside workshop. But I was told changing the repairkit may not last. So far any problem with yours after changing?
Posted: Sun Mar 03, 2013 8:43 am
by maskedrider
klt wrote:I'll be changing the power steering pump repair kit as well. Was quoted about S$200 for parts and labour by an outside workshop. But I was told changing the repairkit may not last. So far any problem with yours after changing?
You can go to Honda agent at JB which just after Taman sentosa along the road side
Locate beside BH, shell station
My CP brought from there, repair or service still cheaper then Kah Motor
You can drive there and ask for quotation, all service staff very friendly and understand English
Just drive straight to the service bay and not to the show room
Posted: Mon Mar 04, 2013 5:24 am
by richcel313
So far so good it,d been fixed 4mths ago but touch wood la.
Ya if you wanna have a peace of mind just get a new replacement.
Posted: Mon Mar 04, 2013 11:35 pm
by klt
maskedrider wrote:klt wrote:I'll be changing the power steering pump repair kit as well. Was quoted about S$200 for parts and labour by an outside workshop. But I was told changing the repairkit may not last. So far any problem with yours after changing?
Hi Maskedrider, what's the name of the shop? Yong Ming? BTW what is BH?
Posted: Mon Mar 04, 2013 11:37 pm
by klt
richcel313 wrote:klt wrote:I'll be changing the power steering pump repair kit as well. Was quoted about S$200 for parts and labour by an outside workshop. But I was told changing the repairkit may not last. So far any problem with yours after changing?
I will change the repairkit just like you la. Changing the whole unit is expensive. BTW where is the workshop you had yours repaired?
Posted: Tue Mar 05, 2013 10:57 pm
by richcel313
klt wrote:richcel313 wrote:klt wrote:I'll be changing the power steering pump repair kit as well. Was quoted about S$200 for parts and labour by an outside workshop. But I was told changing the repairkit may not last. So far any problem with yours after changing?
you can go to ah heng, his workshop at Ubi.
Posted: Mon Sep 09, 2013 11:13 am
by lelynx
do you have the part number for the repair kit for CP2?
