Need advise on very bad FC (cl7a)
Ixnnie
Postby Ixnnie » Wed Dec 12, 2012 11:43 am
Hi all. I need advise on my car's petrol consumption.
Details as follows:
5 years old
138918 mileage
17" inch rims
CSC5 225/45/17
HKS exhaust
Stainless steel air intake
rest all stock
60% city
40% expressway
FC currently is very bad, 350km light up. Sometimes even 330!
Previously was not so bad can run 450. since then I have only changed my body kit and engine oil.
changed to idemitsu and now just changed to motul.
Iridium spark plugs.
Pumping esso98.
Normal footer.
Any advice from bros very much appreciated. If more info required just let me know.
Maybe can also gai siao any workshop to assist me.
Thanks everyone!
MrMurderman
10 000rpm Over Rev
10 000rpm Over Rev
Postby MrMurderman » Wed Dec 12, 2012 5:19 pm
try to clean your throttle body or try resetting your ecu...
殺很大!ï¼
lfwd15
Postby lfwd15 » Wed Dec 12, 2012 7:35 pm
what is the engine oil rating?
recoiler
Postby recoiler » Wed Dec 12, 2012 8:02 pm
Hi there
try changing fuel filter,
worked for me
maskedrider
Postby maskedrider » Wed Dec 12, 2012 8:55 pm
Change back to your pervious engine oil
Clean your air filter
Kyosho MP9 TKi OS V spec AKA tires Sanwa Blue thunder Spektrum
Ixnnie
Postby Ixnnie » Wed Dec 12, 2012 9:56 pm
MrMurderman wrote:try to clean your throttle body or try resetting your ecu...
I have checked my throttle body and advised that it does not require cleaning and i have also removed my unichip and resetted the ECU, still the same ):
Ixnnie
lfwd15 wrote:what is the engine oil rating?
Motul 5W40 bro...
Ixnnie
Postby Ixnnie » Wed Dec 12, 2012 9:57 pm
recoiler wrote:Hi there
worked for me
Yes bro, I have already changed it on my last servicing...
Ixnnie
maskedrider wrote:Change back to your pervious engine oil
Noted, maybe any bro can recommend ?
Easiboyz
FC
Postby Easiboyz » Thu Dec 13, 2012 12:10 am
Bro, drive slowly to warm up your car. Don't idle to warm up. Check your tyre air pressure and observe your fuel mixture, too rich may be
lonerCL7a
Postby lonerCL7a » Thu Dec 13, 2012 1:57 pm
Never attempt to clean your throttle body as they have a protective film applied to it.
With good knowledge of theory is fine, but put it in practical. Cos with good theory and no practical experience, all theory is bull shit!
Ixnnie
Postby Ixnnie » Thu Dec 13, 2012 8:48 pm
Thanks for the response guys. I plan to give my engine oil a change.
Any kind bros able to recommend ?
Thanks!!
Accord515
Postby Accord515 » Thu Dec 13, 2012 8:55 pm
Ixnnie wrote:Thanks for the response guys. I plan to give my engine oil a change.
Thanks!!
I am using elf 5W40, FC around 9.5-10km/L, 40/60 exp/street. Caltex 95.
Ixnnie
Postby Ixnnie » Thu Dec 13, 2012 10:22 pm
Thanks!!
ELF Excellium ??
huffie
Re: Need advise on very bad FC (cl7a)
Postby huffie » Fri Dec 14, 2012 11:10 am
Ixnnie wrote:Hi all. I need advise on my car's petrol consumption.
60% city
40% expressway
Pumping esso98.
Normal footer.
Thanks everyone!
how you define a normal footer? never exceed 3k/4k/5k rpm? check ur air filter, aircon filter and make sure ur spark plug is the right temp
Return to “Accord”
