D2 Coilover Shocks on Euro R
jaymen
Post by jaymen » Tue Oct 23, 2012 2:56 pm
Hi bro's,
Test drove a car yesterday which had D2 Coilover Shocks.
It felts more stiff than the standard.
Anyone used this before? Is it any good? Whats the price of these shocks?
Regards,
Sanjay
civic_1986
Bcbr
Post by civic_1986 » Tue Oct 23, 2012 5:19 pm
Im on bc br. Stock from fk is 10kg front 5kg rear but I felt too soft so I asked for 12 front 10 rear. And stiffer damper rates. Now car is very good. As stiff as fd2r. If u have family to fetch den stick to 10 , 5.
jaymen
Re: Bcbr
Post by jaymen » Tue Oct 23, 2012 5:35 pm
civic_1986 wrote:Im on bc br. Stock from fk is 10kg front 5kg rear but I felt too soft so I asked for 12 front 10 rear. And stiffer damper rates. Now car is very good. As stiff as fd2r. If u have family to fetch den stick to 10 , 5.
Thanks bro your input
BlackKnight_CM5
Post by BlackKnight_CM5 » Fri Oct 26, 2012 7:27 am
Forget D2..its too stiff. Used that and changed out immeditaely :lol:
jupiters319
Re: D2 Coilover Shocks on Euro R
Post by jupiters319 » Fri Oct 26, 2012 5:46 pm
jaymen wrote:Hi bro's,
Regards,
Sanjay
Was quoted 1780 with installation & alignment, replacement parts are low costing. But going for API, 1570. :)
jaymen
Post by jaymen » Sat Oct 27, 2012 12:15 am
Thanks bro's jupiters and blackknight for sharing.
Anyone has any idea how much the Standard Shocks cost?
Quite honestly I prefer the standard shocks, this did feel very stiff for me..
viper76
Post by viper76 » Sun Oct 28, 2012 9:35 am
jaymen wrote:Thanks bro's jupiters and blackknight for sharing.
ur car on wat shocks now???
jaymen
Post by jaymen » Sun Oct 28, 2012 12:01 pm
D2 Coilover bro
YEN96
Post by YEN96 » Sun Oct 28, 2012 8:33 pm
i will take BC, ISC, APi anytime over D2.
viper76
Post by viper76 » Sun Oct 28, 2012 9:26 pm
Regards,
Sanjay
sanjay the d2 coilover can set to softest to hardest damping ...spring rate varies frm different coilover makers i believe...so u might wana play with the damper to set it soft or hard. maybe by setting it u might like the setting??? then no need to waste money getting other shocks....jus my 2 cents...i'm on BC coilover...no complains..
jaymen
Post by jaymen » Mon Oct 29, 2012 12:47 am
Regards,
Sanjay
Thanks for the tip bro
jm passion
Post by jm passion » Mon Oct 29, 2012 10:34 am
Regards,
Sanjay
D2 there few spec example: - street,track racing and super racing.
I sat on circuit racing recently the handling and stiffness is good price wise reasonable so depend what you want before commit. End of the day regardless of brand the mechanic install the coilover also very important and the setting able to do huge diff.
jm passion
Post by jm passion » Mon Oct 29, 2012 10:42 am
Not to promote or sell any garage just as an example what D2 super racing coilover handling when under stress performance on k20 stock engine able to do. : - http://www.youtube.com/watch?v=OWCNihJVTXI
jaymen
Post by jaymen » Tue Oct 30, 2012 12:30 am
Thanks for the share bro
YEN96
Post by YEN96 » Tue Oct 30, 2012 8:16 am
jm passion wrote:Not to promote or sell any garage just as an example what D2 super racing coilover handling when under stress performance on k20 stock engine able to do. : - http://www.youtube.com/watch?v=OWCNihJVTXI
Batman & Robin in the car ???
