If mileage over 100k, change out O2 sensor. FC will improve
Home Of The AirwaveRs
jengwe
Post by jengwe » Wed Aug 15, 2012 10:19 pm
Hi to all,
I have successfully changed out my Pre (6 Ohm heater) and Post (13 Ohm heater) Cat O2 sensors using NTK universal 4 wire O2 sensors. What is critical is the use the correct wattage heater built into the sensor as the wrong wattage will trigger DTC code P0135 or P0141. The Honda Airwave uses 1 pre and 1 post sensor, both from NTK.
Retail price of each “direct fitâ€
raise36
Honda Airwave O2 sensor
Post by raise36 » Tue Apr 09, 2013 8:16 am
Hi Jeng we,
Good day..I'm Raise.Currently driving Honda Airwave 2008 model.Last two week when for diagnotic and found that my O2 sensor,both top & bottom not really working well.
Do you have any stock,prefably the original ones and what is the damage?
Thanks Bro..Hope to hear from u soon...
Thank u & Best Rgd,
A.Raise
Honda Airwave 2008
The Best is still out there........
raise36
Post by raise36 » Tue Apr 09, 2013 8:17 am
Hi Jeng we,
Thank u & Best Rgd,
A.Raise
Honda Airwave 2008
