You guys must be wondering… so many things to buy for the 160K but don’t know what or how the parts looks like… I have the answers….
Firstly let me present the parts list:
1) Honda ATF-Z1 (08268-P99-01251) x03btls $25.50
2) Valve Cover Gasket (12341-PLC-000) x01pc $15.00
3) Spark Plug Seal (12342-P08-004) x04pcs $18.00
4) Timing Belt (14400-PLM-014) x01pc $25.00
5) Timing Belt Bearing (14520-PLC-305) x01pc $65.00
6) Water Pump (19200-PLM-A01) x01pc $115.00
7) CKP-Low Crank Sensor (37500-PLC-015) x01pc $75.00
9) Aircon (Compressor) Belt (38920-PLC-003) x01pc $16.00
10) Power Steering Belt (56992-PLC-T01 (J)) x01pc $16.00
11) Washer Cover (90442-PLC-003) x05pcs $20.00
12) Timing Oil Seal, 38x50x7 (91212-PR3-003) x01pc $8.00
13) Camshaft Oil Seal, 29x45x8 (91213-PD2-004) x01pc $8.00
14) Spark plug (IK20L) x04pcs $64.00
15) Oil Filter (your choice) $8.00-$10.00
16) Honda Long Life Coolant (08C04-EX1000) x04btls $34.00
Optional parts to change during your major service (that is….. If you want to…):
1) Plug Cylinder Head (12513-P72-003) x01pc $10.00
2) Thermostat (19301-P08-315) x01pc $18.00
So there you go! The pics! -> -> ->
Unwrapped!
Underside
Closeup..
Timing Belt (14400-PLM-004) x01pc $25.00
The groove should look like this….
Belt printing….
The other side of the bearing…
TDC Cylinder Assy Sensor (37840-RJH-006) x01pc $65.00
See the groove, should look like this.. felt feeling….
See the groove, should look like this… Felt feeling too!!!
Don’t worry about the metal exposure. It does not affect the usage of this…
Close up on the inner profile…..
Remember! Check out bro MaKH post on how to check the real and the fake ones before buying!!!!!
And don’t forget your Engine Oil!
So there you go! All that you need to perform your 160KM service! ï
