jbt brakes
jbt brakes
Hi guys,
Anyone using JBT? How is it?
TIA for ur feedback on this...[/i]
- pReTeNd3R
Re: jbt brakes
If its meant for street drive only, it's value for $. Go for big JBT frm fcuking att Yap bros and not mini JBT... Brand new is abt $1800 w install I thinkhammerdin wrote:Hi guys,
- bernardyap
- 1000rpm
Using the JBT 4 pot with JBT 330mm 2piece drilled rotors and VTTR 50-550 temp pads, including front and rear steel hoses. Got a barely used second hand set for $1050. I read up on the reviews on the JBT brakes and it seems like its pretty well received even on Aussie, US forums for trackies and drifters
For spirited street driving.... Way more than enough. Firm brake feel, low dust, no sound and significantly shorter braking distance. The bling factor is also awesome from the red calipers and drilled rotors almost filling up my 17in SSR Type F rims
For track? I dunno cos haven't tracked with this brakes yet. Anyone has feedback from using this brake on the track?
- viper76
bro i guess u using 4 pot mini ....i hv no comments on mini 4 pots cos nvr use b4...if u wanna go track best to use big 4 pot...last time i use big 4 pot on track,,,i can say jbt big 4 pot is gd....charcoalx wrote:Using the JBT 4 pot with JBT 330mm 2piece drilled rotors and VTTR 50-550 temp pads, including front and rear steel hoses. Got a barely used second hand set for $1050. I read up on the reviews on the JBT brakes and it seems like its pretty well received even on Aussie, US forums for trackies and drifters
