Help! Fender Roll issue! Urgent
speedsterdarren
Post by speedsterdarren » Sat Mar 03, 2012 9:57 am
Hi folks as per abovementioned..would like to ask if any bros here ever did full roll fender on our ride before??cuz Just bght a 15mm lug spacer to achieve flush effect but only to realise that my rubbers are sitting just right above my fenders(unrolled flat portion)
So my question here is..do i need a full fender roll of just partial(my fren did at htyre) assumming my suspension settings is of medium hardness...
i used to be on 8JJ +35 offset...now ive changed to 7.5JJ +40 offset..the rims kind of went a bit inwards and looks pretty weird to me
Thanks in advnce for all kind inputs.. :lol: :lol:
speedsterdarren
Post by speedsterdarren » Sat Mar 03, 2012 11:13 am
any bros here on 7.5JJ with +40 offset and 15mm spacer??if yes pls advise what u did to your rear fender...thks in advance :lol:
crazy nut
Post by crazy nut » Mon Mar 05, 2012 2:23 pm
speedsterdarren wrote:any bros here on 7.5JJ with +40 offset and 15mm spacer??if yes pls advise what u did to your rear fender...thks in advance :lol:
hello. i have used b4 8.0JJ and +30 offset on my car b4. so i think that will come out more than your 15mm spacer or prolly same. there is nothing else you can do to your rear fender except to roll it. find uncle lye...
all motor is the way to go.
speedsterdarren
Post by speedsterdarren » Mon Mar 05, 2012 4:46 pm
thks bro for the reply...Unlce lye did a full roll for you??full roll means the fender basically folds to the back like a piece of paper... :lol:
crazy nut
Post by crazy nut » Mon Mar 05, 2012 9:53 pm
yes something like tt... u gotta see it to know it.. after rolling.. it worked for me.
speedsterdarren
Post by speedsterdarren » Tue Mar 06, 2012 9:37 am
crazy nut wrote: hello. i have used b4 8.0JJ and +30 offset on my car b4. so i think that will come out more than your 15mm spacer or prolly same. there is nothing else you can do to your rear fender except to roll it. find uncle lye...
Ok thks bro..will drop by Uncle Lye to check it out..Thks a lot bro :lol: :lol: :lol:
rayray888
Re: Help! Fender Roll issue! Urgent
Post by rayray888 » Thu Nov 01, 2018 11:42 am
speedsterdarren wrote:Hi folks as per abovementioned..would like to ask if any bros here ever did full roll fender on our ride before??cuz Just bght a 15mm lug spacer to achieve flush effect but only to realise that my rubbers are sitting just right above my fenders(unrolled flat portion)
Fender Roll Bros at Serangoon. One & Only Home-Based. $50 each side. Whatsapp 9002 9923.
rayray888
Re:
Post by rayray888 » Thu Nov 01, 2018 11:43 am
rayray888
Re:
Post by rayray888 » Thu Nov 01, 2018 11:44 am
Fender Roll Bros at Serangoon. One & Only Home-Based in a Sheltered Bungalow. $50 each side. We will HAMMER, ROLL, TRIM to the MAXIMUM for you at one price, $50 each side. Whatsapp 9002 9923.
rayray888
rayray888
Re:
Post by rayray888 » Thu Nov 01, 2018 11:45 am
rayray888
Re:
Post by rayray888 » Thu Nov 01, 2018 11:46 am
rayray888
