Sometimes car have difficulty cranking
Any bros here experience this problem whereby i turn the ignition key nothing happens? Got to clutch in again and then able to fire up. Sometimes crank halfway stop then i need to crank again. My battery is new by the way. Could it be the battery terminal or the starter is weak?
Re: Sometimes car have difficulty cranking
Maybe alternator not charging enough?totallypatrick wrote:Any bros here experience this problem whereby i turn the ignition key nothing happens? Got to clutch in again and then able to fire up. Sometimes crank halfway stop then i need to crank again. My battery is new by the way. Could it be the battery terminal or the starter is weak?
Check your started motor too.
