CL7 Wiper Blade Refill
sparcoR
Post by sparcoR » Sun Nov 27, 2011 6:42 pm
Would like to know does anyone here know to replace the CL7 wiper rubber?
Wanted to change the rubber but don't know how to take out.
Hope that someone can enlighten me.....
Thanks.
XsenseX
Post by XsenseX » Sun Nov 27, 2011 10:35 pm
Me too ... Heard can buy from tian seng?
But i got my CL7 second hand so not sure how to see if the wiper was changed to aftermarket or not ...
lfwd15
Post by lfwd15 » Sun Nov 27, 2011 11:15 pm
It's not difficult but just time consuming.
I did mine years ago.
I think you try to pull at the side to get the metal bone out. It is the metal bone in there that keeps the rubber in place...
Hope this helps...
Wayan
Post by Wayan » Mon Nov 28, 2011 12:29 pm
less than 10min :wink:
Its not the size of your nose that matters but it is how you honk it..
sparcoR
Post by sparcoR » Mon Nov 28, 2011 6:31 pm
Wayan wrote:less than 10min :wink:
Hi Bro,
Can enlighten me on how to do it???
I still not able to figure out.....Tks.....
EasternCanuck
Post by EasternCanuck » Mon Nov 28, 2011 7:38 pm
There is a clip that you need to pull at the center of the wiper to get it off.
I went to Autobacs and the guy came down to the carpark, took them off for me, then took me back to the store and showed me what would fit. I bought them and then he came back down to the carpark and put them back on for me.
Not bad service. :-)
weishien
Post by weishien » Mon Nov 28, 2011 11:25 pm
EasternCanuck wrote:Hi,
Yeah, me replaced my wiper there last time n they did same thing
8)
Everything stock, including the driver...
Wayan
Post by Wayan » Wed Nov 30, 2011 2:54 am
Hi Bro,
got to show u "live" lorr..hehehehe
sparcoR
Post by sparcoR » Thu Dec 01, 2011 9:20 pm
Hi, Thanks for the info but i juz did it the lazy way of doing which is I went Autobacs and buy the refill & ask the staff to change for me....
sparcoR
Post by sparcoR » Thu Dec 01, 2011 9:21 pm
Wayan wrote:
Hi Bro,
hahaha.... :D
Yaloryalor
Post by Yaloryalor » Sat Dec 03, 2011 12:40 am
Autobacs got the refill for our orginal wiper?
EasternCanuck
Post by EasternCanuck » Sat Dec 03, 2011 7:49 am
No, they said they couldn't do a refill. But they have a wiper that looks identical.
sparcoR
Post by sparcoR » Mon Dec 05, 2011 10:57 pm
Yes Bro... I went Bt Batok Branch.. But they onli got the refill for the short wiper. As for the long 1, have to wait for the stock to come in....
The brand i change is PIAA...Silicon
flyby
Post by flyby » Wed Feb 27, 2013 4:02 pm
success~!
i only had long wiper frame with me. bought from thien seng short wiper frame (comes with rubber) $6x and long wiper rubber $1x
how to replace:
its really 10mins or less if you know what you are doing. the follow sounds complicated if you dun have the parts in your hands. once you see the parts, you will have an idea what to do.
old rubber can be pulled out with some force, not a lot is needed. out comes the rubber with 2 long metal rods/wires. these metal pieces fits in the gooves of your new rubber. you will understand once you see it.
you only need to fit a short length of the metal into the rubber at the tip. then feed this tip like a train on tracks into the wiper frame.
Wayan
Post by Wayan » Thu Feb 28, 2013 7:20 pm
has this issue been settled yet? :D
