boot leaking water
Civic model year 1980 - 2000
marcus85
boot leaking water
Post by marcus85 » Fri Nov 11, 2011 1:36 am
hi bros,
need some help. I've been facing water leaking into my boot. Now especially rainy season, i could keep goldfish in the area where i keep the spare tyre.
Anyone experienced this problem before or any workshops to recommend to fix this?
thanks
Emperorcivic
Re: boot leaking water
Post by Emperorcivic » Fri Nov 11, 2011 7:08 pm
marcus85 wrote:hi bros,
thanks
welcome to the world of EG. lol.
i used to have this problem. and i newspaper my boot during rainy seasons.
SGTHAL
Post by SGTHAL » Fri Nov 11, 2011 10:34 pm
Used to Face the same prob. I found the cause of leak after a 6 month test an errand. I realise the leak to be if your car is hatch to be the rubber lining of the rear window panel. I bought silicon from hardware shop and patch myself. If its 4dr which I have driven the ek, the leak was at the side panel which has a small opening and I silicon that up too.
icute23
Post by icute23 » Sun Nov 13, 2011 10:22 am
U might wan to change the rubber lining at your boot.... Was having same problem as your .... Change already problem solve
HOP Honda Original Parts........
marcus85
Post by marcus85 » Tue Nov 15, 2011 10:16 am
Found the water to be coming in from the tail lamps.. put silicone and see whether can tahan. If cannot, den will need to bring to workshop to fix liao. sian....
ethene
Post by ethene » Thu Nov 17, 2011 7:58 pm
mine also same problem.... and it seems that water coming from weird place, workshop say my rear window lining got leak. i mean wtf ?!
esi06
Post by esi06 » Thu Nov 17, 2011 11:51 pm
ethene wrote:mine also same problem.... and it seems that water coming from weird place, workshop say my rear window lining got leak. i mean wtf ?!
Rear seat always when raining. Dunno where the water coming in from...
Emperorcivic
Post by Emperorcivic » Mon Nov 21, 2011 6:26 pm
maybe u touch the seats too much? lol. jus kidding.
check ur sunroof.
mine had sunroof leakage on really heavy rain.
YEN96
Post by YEN96 » Tue Nov 22, 2011 12:03 pm
if rear seats wet during heavy rain, check the slots where the rear seat belts come out....most likely water coming in from there and trickle down the seat belts to the rear seat.
ben5314
Post by ben5314 » Fri Dec 23, 2011 5:09 pm
mine also... mine is on the right hand side... knn don know where the fxxx the water come from.... check here the there.. silly-con here n there... water still come out when raining... think 1 of the bro here say there is a hole or something like that... pls advice me... thanks many many...
Do wat u wanna do coz u wanna do it...
ben5314
Post by ben5314 » Fri Dec 23, 2011 5:12 pm
SGTHAL wrote:Used to Face the same prob. I found the cause of leak after a 6 month test an errand. I realise the leak to be if your car is hatch to be the rubber lining of the rear window panel. I bought silicon from hardware shop and patch myself. If its 4dr which I have driven the ek, the leak was at the side panel which has a small opening and I silicon that up too.
bro im driving EK4 sedan.. the leak is at the right handside closer to the tail lamp... don know where the hell the water come from... pls advice... BTW i silly-con here n there liao still the same....
icute23
Post by icute23 » Fri Dec 23, 2011 7:01 pm
Try changing the boot rubber seal .... I also silicon my tail lamp also no use until change the boot rubber seal then problem solve Liao
vampirus
Leak
Post by vampirus » Fri Dec 23, 2011 8:11 pm
My ek sedan back seats on the right side leaks damn. Door or window does seem to leak
So come out.. come out.. wherever you are...heh heh
ben5314
Post by ben5314 » Sun Dec 25, 2011 1:36 pm
Thanks bro... might change it soon n c how it goes... anyway just rem got 1 more area leak... fxxx... left door panel, speaker area a bit leak also... haizz... tok of goin to strip the whole car & re-do the body... anyway im goin to drive till the end till 2018... so might as well re-do the whole thing n worry no more... haizz.. but think of the cost that goin to spent to redo... i wanna cry...
Silver
Post by Silver » Mon Dec 26, 2011 3:24 pm
Pain pain one time do swee swee since you are going to drive till 2018... No regrets de... :wink: :wink:
