Honda Stream Vibrates when aircon cuts in
Posted: Sat Oct 01, 2011 4:23 pm
by bendof
Hi does any stream owner have this issue.
I had change all the mounting .It only vibrates when aircon cut in.
Thanks
Posted: Wed Oct 05, 2011 12:01 am
by brokencar
That's because rpm drops. Try with slightly higher rpm
Posted: Thu Oct 06, 2011 9:45 pm
by bendof
brokencar wrote:That's because rpm drops. Try with slightly higher rpm
Err bro how to adjust to higher rpm? I asked autosaver but they say rpm cannot adjust. Mine without aircon, idling is about 700. with aircon about 800 - 850. Is it normal?
Posted: Fri Oct 07, 2011 10:48 pm
by Silver
Rpm is at normal range.. :) :)
Re: Honda Stream Vibrates when aircon cuts in
Posted: Wed Oct 12, 2011 11:56 pm
by ronyyk
bendof wrote:Hi does any stream owner have this issue.
Thanks
Same experience. Have given up to fix the vibration problems, after countless argue with Kah Motor. As, I have learnt that Honda's Aircon Fan cut in full speed everytime when it operates. But, some other brand does not, so lesser vibration when it operates.
