Broken compartment can be fixed?
- EasternCanuck
My new,second hand, CL7A has a broken compartment and I am wondering if it is possible to either fix it or replace it?
It's the fold down compartment on the driver's side, bottom right of the steering wheel. I have the compartment but the guy who owned it before me broke the little clasps.
Can this part be purchased here? Worth replacing if I can't fix it?
EC
EC
- pReTeNd3R
Re: Broken compartment can be fixed?
I think you try go to thian seng at Waterloo street.EasternCanuck wrote:My new,second hand, CL7A has a broken compartment and I am wondering if it is possible to either fix it or replace it?
EC
- EasternCanuck
- EasternCanuck
- fatelmo
- East Deviants Moderator
Nobody knows everything. I am sire we are all learning everyday. It is just a matter of you learnt them early or laterEasternCanuck wrote:Thanks!
They were most kind to invite to the last one but my ride only came this past Friday.
Not too sure I'd know what they were talking about in their discussions. I'm very 'noob' with this kind of stuff - but I'm enjoying the learning process.
EC
Tml I might be doing some DIY at one of the MSCP along Marine Parade. If free pop by
- viper76
bro DIY wat sia ??fatelmo wrote:Nobody knows everything. I am sire we are all learning everyday. It is just a matter of you learnt them early or laterEasternCanuck wrote:Thanks!
EC
Bro,EasternCanuck wrote:My new,second hand, CL7A has a broken compartment and I am wondering if it is possible to either fix it or replace it?
EC
I also recently broke that little clasps. Tried using super glue to stock back, but the force to lock the bracket to the clasp is still too much.
I think might have to replace the panel... but if you found the solution, pls tell me.
Ok I am going to suggest this cos I broke mine within a week of receiving my brand new CL7. Not sure which part is broken on yours but Mine broke at the plastic stub that sticks out which snap locks it in place. I mended it by screwing a self tapping screw to reinforce it together with epoxy 2 part glue. Took a bit time for everything to set but managed to get it done.transparent_days wrote:Bro,EasternCanuck wrote:My new,second hand, CL7A has a broken compartment and I am wondering if it is possible to either fix it or replace it?
EC
- EasternCanuck
Will do! Hope to get there this weekend - couldn't find the time before.transparent_days wrote:Bro,EasternCanuck wrote:My new,second hand, CL7A has a broken compartment and I am wondering if it is possible to either fix it or replace it?
EC
EC
Bro,2cubed wrote:Ok I am going to suggest this cos I broke mine within a week of receiving my brand new CL7. Not sure which part is broken on yours but Mine broke at the plastic stub that sticks out which snap locks it in place. I mended it by screwing a self tapping screw to reinforce it together with epoxy 2 part glue. Took a bit time for everything to set but managed to get it done.transparent_days wrote:Bro,EasternCanuck wrote:My new,second hand, CL7A has a broken compartment and I am wondering if it is possible to either fix it or replace it?
EC
Just to confirm the steps
You use a self tapping screw to screw onto the existing plastic stub that broke off and onto the panel?
Of the self tapping srew is to replace the broken stub?
Becos the existing stub is so small, how can it be done?
transparent_days wrote:Bro,2cubed wrote:Ok I am going to suggest this cos I broke mine within a week of receiving my brand new CL7. Not sure which part is broken on yours but Mine broke at the plastic stub that sticks out which snap locks it in place. I mended it by screwing a self tapping screw to reinforce it together with epoxy 2 part glue. Took a bit time for everything to set but managed to get it done.transparent_days wrote: Bro,
I used a pretty small screw (slightly bigger than the spectacles type) to screw thru both the stub and holder. Also glued with epoxy.
- EasternCanuck
