New Honda city, Not smooth when gear changes
Posted: Sun Jul 17, 2011 6:44 pm
by eug3n3_ang
Hi guys,
Anyone encounter same problem on the gear change from 1 to 2 and 2 to 3. Feels like there is a force pulling back when switching gear.
Somehow the same feeling when i drive manual and throw clutch.
Is it becoz i nv step enough accelerator?
May i know how to solve it?
Thanks in advance.
Re: New Honda city, Not smooth when gear changes
Posted: Mon Jul 18, 2011 10:02 am
by Silver
eug3n3_ang wrote:Hi guys,
Thanks in advance.
City auto?
Posted: Mon Jul 18, 2011 3:18 pm
by eug3n3_ang
Yup.auto city 09.
Posted: Tue Jul 19, 2011 9:46 pm
by Silver
Go back to Kah Motor as car is still under warranty and get then to check out the problem... :) :)
Posted: Wed Feb 13, 2013 11:50 pm
by symym
[quote="eug3n3_ang"]Hi guys,
Thanks in advance.[/quote]
Bro, did you get it fixed? I'm having the same problem when moving off from cold engine. KM told me it is normal.
Posted: Thu Feb 14, 2013 10:53 pm
by fiqueudrue
i think its normal.
usually when you do servicing, you got the smooth n power, but after a while, surge/pull back comes again.
can try using thinner engine oil to feel responsive
Posted: Thu Feb 14, 2013 11:40 pm
by alvinchoo86
I think it's normal too. Use thinner engine oil. Do regular servicing. To further extend , I can intro u to go clear the carbon sludges.
Also cold start dun expect much, engine is not at its best state.
Posted: Wed Feb 20, 2013 3:16 pm
by whaleson
Check CVT fluid.
Posted: Wed Apr 24, 2013 11:51 pm
by funkychicken
Change engine oil and transmission oil. Use oem honda atf or hmmf fluid for ur car. Basic servicing is critical. Clean air filter if u using drop in or oem one change. All this basic servicing need to do religiously. For a start wif ur air filter. Can be cause by lots or reasonsbut always start wif basic servicing when troubleshooting.
